m1lky
I normally just run a bit of clear plastic hose and a funnel down the drivers side of the car and into the filler hole and tie the funnel to the mirror if a hand pump isn't available.
The mk1 EF was the last model to have a dipstick, they were deleted because muppets kept putting the old dextron gloop into the transmission instead of the required oil and wrecking their transmissions. They still had the little fitting on the transmission for a dipstick right up until the 4 speed was discontinued, a lot of taxi operators retrofit them.
I was going to use a bit of plastic pipe. Mate of mine has a gun I've used for diffs before but they're a pain.
Ford and the penrite website say dextron iii for the 4 speeds. Is this not correct?
