Battle of the V8 Statesman's! Revhigh STREET DOMINATOR CAM PACKAGE! Warning lumpy!
Revhigh
Dandenong South
Holden VF Maloo
We do a lot of Holden V8 Cam packages! These 2 back to back Stato's with the same cam and supporting mods were custom tuned and produced almost identical power delivery! Our new heat shield coated Headers keep the engine bay temps down by more than 28c on hot days!!
For more information please contact us or view the below links!
Jeda
WN Caprice V
How much for the cam package on an L77 Caprice?
Already have full exhaust and VCM OTR.
Revhigh
Dandenong South
Holden VF Maloo
H Jeda!
Our cam packages are $3300 and our Melling pump, chain and tensioner ugprade package (with sump drop and clean which is recommended) is $700.
Revhigh
Dandenong South
Holden VF Maloo
Jeda
WN Caprice V
Thanks for your reply.
Does that include removal of the DOD component's?
Also, do you have a cam that I can run without a high stall converter?
Revhigh
Dandenong South
Holden VF Maloo
The extra hardware needed for DOD is $250, our 225/236@114 LSA Billet Camshaft with supporting mods about 310-320rwkw) is about as big as you can go on the stock stall, will need a full exhaust and OTR to run it nicely though. It will have a bit of push on the pedal but it is bearable, otherwise we can go a smaller cam, around the 224/224@112 LSA (280-290rwkw) mark without any push.
Jeda
WN Caprice V
$4250 for the package then.
When can I book in?
Revhigh
Dandenong South
Holden VF Maloo
When can I book in?
Hi Jeda!
We can get you in next month! Can you PM your number or call us on 0390016375 and say you were talking to us on justcom? We can organise a booking for you. Thanks very much
