Bloody iac valve
Mick1988
W.A. Cruise Moderator
35
Perth, Western Australia
www.sarichtechnology.com
Too many to list......
mate my problem is so clear i dont know why ur not getting it. the problem is(AGAIN IN ENGLISH) whenever i dis the plug from the IAC VALVE the idle speed remain the ####en same no change in the idle even if i turned on all the acc or the air condition the idle speed still catch up.
Pretty sure you shouldn't swear at me mate. Also pretty sure you should go back to kindergarten english classes.
And if your car runs fine when you disconnect the IAC valve as it's idling, then it's probably because the solenoid is just staying open. Try disconnecting it when the car is doing a few revs then see if it will idle. Or translated so you can understand it "if you dis the plug from the IAC VALVE when da car is on idol the ####en valve is already ####en open its just solenoid try dis it when car is at revs much".
1dvsbstd
Perth Australia
VE SV6 SERIES II 2016
Wow this thread really makes my day bahahahahahahahahahahahaha
DLFHUB666
GIT 'EERRR DONE!!!
39
Nhulunbuy NT
VX SS, PX Ford Ranger XLS Dual cab
at mick 1988 :rofl::rofl: Rep given.
slowandlow
dandenong
vy executive
sounds like the iac valve is stuck. try replacing it. they arent too expensive, and easy to change
