Body rubber/seal on roof perishing
z900collector
99VT 99VSUTE
G'day all,
I have a 1999VT Equip which has the two seals on the roof (running front to rear) perishing, are these an easy to replace item and still available?
Thanks
Sid
Fu Manchu
WA.
No longer available new. Can use VT-VZ. It’s just a trim, not a seal so nothing will happen if it is rubbish looking.
Aus78Formula
VX R8 Clubsport
They can still be found new, not cheap. Plastic coated aluminium strip, some may be plastic only. Some remove to respray but will often break the clips to do so, the clips are also expensive. Given the price and trouble, if made it that far easier to just replace the part, comes with clips. X2 it's just a cover.
