broke the oil filter cover please help????
05 Calais
70
Port Macquarie
VZ alloytec Calais
The whole filter housing unbolts and comes away , there is one on ebay complete for 125 , search for VE/VZ oil filter canister assembly
RiCeY
F O R U M W A R R I O R
Australia
VZ SV8 6spd 6.0 430rwhp
greenacc
Searching for the billion
VE Berlina
My mechanic had a go at me for not doing the cap or the plug up tight enough .... ( even though i torqued them to spec )
RiCeY
Australia
Cap doesnt need to be tight at all, once the cap is flush with the housing ie no gap above the thread just nip it up a tad more and youre done.
loopie
sa
vx
serviced my mates vz today, i had to get the impact rattle gun out. to remove the filter cap...then a breaker bar out for the sump plug..a toyota dealer serviced it last time..why so tight it dosent need to be????
RiCeY
Australia
Because some people are idiots.
MindPiss
Australia
vz,vs.. au.. pajero
i put a 24 mm which was slightly to big over it with the breakerbar .. but dont have imperials atm..anyway itdidnt budge the cap.. just rotated and got wedged on( whats the term for that??)... gonna try an oil filter wrench later but i spose if that dont work ill just top myself.. what do yas reckon ? sound plan?..
kiwicon
NZ
VS V8 Manual
smash a big screw driver thru the filter and twist.. had to do that a few times.. - double check the new filter to which way you turn first thou.. don't want to tighten it up more..
Gaiter
VZ SS Thunder
Had to do this on the weekend. Hammer and the biggest Phillips head I had did the trick.
Had to put three holes in it, one at a time then spin as far as you can, then repeat. Bit of oil came out as I did each hole, had the pan and some newspaper under the filter before I did it. Got it off easily enough that way.
On my VZ looking up at it, I had to turn it clockwise.
stick3
newcastle nsw
vz sedan vs ute gsx1400
^^^this thead is about the v6 alloytec where the oil filter is above the engine....... anyway if u need another filter housing vz filte housing | eBay
