Brown stuff in cooling system
Jesse.15
Vy
Can anyone tell me what this wet tissue like substance is in my radiator ?
lowandslow
NSW
V2 III Monaro
What does your engine and transmission oil look like?
Has the car ever had a coolant change? If it's not oil in the coolant it could just be the left overs from the holden radiator additive.
gossie
Gold Coast.
VE International 3.6L
It needs a proper good flush out and the green coolant replaced NOW.
Trevor 062
60
St Clair
2012 VE S2 SSV REDLINE & 07 VZ ACCLAIM WAGON
Your inlet manifold is rooted, needs changing & the whole system flushed out
scozz76
Largs Bay, Adelaide, S.A
VF 2014 Evoke - VYII Acclaim
As above, sounds like the intake manifold. I Recently changed the gasket on my VY for the same problem.
Jesse.15
Vy
I have only just done my coolant about 5 months ago.
Does this mean I have done a head gasket?
chrisp
Melbourne Victoria
VF2 MY16 SS Redline Sportwagon
As others have already posted, it is more likely to be the inlet manifold gaskets. It's a common problem and easily fixed. Search for v6 valley gasket or v6 inlet manifold gasket.
wortus
Before you pull it all apart and replaced the gaskets just check that the inlet manifold nuts are not loose. I had a bit of oil in my radiator years ago now. I found the dome nuts holding the inlet manifold down were all loose. A quick tighten up and several years later no sign of any oil in the coolant or coolant in the sump.
Clarky57
60
Bega NSW 2550
VY Executive L67 V6 sedan
Looks like one of the plastic intake manifold gaskets has cracked and is leaking oil into the coolant and will get worse , these get brittle over time and I've heard they should be replaced at 150,000Ks ... I'd recommended you buy a pair of the aluminium ones you can get from Mace Engineering for about 95 bucks ... why the hell Holden never fitted them instead of the plastic ones (like the in the US Buick V6) is beyond me ... as said above, its a common problem and easily fixed but I'd go for the aluminium gaskets especially if your going to keep the car
