Building a torque monster 308/355
ricky.chuckles
37
Mooroopna
TK Bedford
Hey guys and gals i need some advice.
I have just acquired a TK Bedford truck. Yeah ok its not a commodore but it has a 308 in it.
Having driven it, the engine is fairly healthy, makes alot of noise but doesn't have a lot of power/torque
The old girl weighs about 3 ton empty and its never going to carry much more than a car.
The engine has to come out so i can restore the old girl, so a rebuild is in store.
As far as i can find out off the previous owner, the engine is a virgin bore turbo pattern block.
So where do i go with this engine? 355 stroker? Turbo? Blown?
I will be building it myself. i want good torque from approx 2000rpm and it wont be revved much higher than 5000rpm.
I was thinking along the lines of either a standard stroke engine or a 355 with good rods and pistons, vn heads, ebay TO4 turbo running 6psi through a blow through carby.
I'm even open to going straight lpg because space for tanks isnt a problem.
Any advice would be great thanks
mr j-man
GC
VH SL/E 355
seems like you already have it sorted, could run e85 if u wana go down that track
Darren_L
Toowoomba, Qld
VH SS
wouldn't you be better off with a supercharger if you want the torque right across the entire rpm range ?
I realise trucks use turbos, but diesels are a very different animal to a petrol engine
Immortality
Staff member
Sth Auck, NZ
Cubes = easy torque so definitely go the stroker route.
ari666
250,000 hits
conp
Australia
VYSV8
Strokers are not as reliable as a standard bore. I'd stay with the 308 engine and give it a rebuild with some light head work and a small torquey cam like a crow 602, small 4 barrel Holley and call it a day. Stay with the old school technology and you can't go wrong.
Cava454
35
Box
VR SS, VZ SS
BBC if you can afford it. If not turbo the sucker
mr j-man
GC
VH SL/E 355
what about BBW
ricky.chuckles
37
Mooroopna
TK Bedford
Ok what is a good turbo cam? Something to spin the snail up nice and early
Sent from my RM-821_apac_australia_new_zealand_218 using Tapatalk
Immortality
Staff member
Sth Auck, NZ
You need to match the turbo to suit the engine. Doesn't matter what cam you have, if the turbo's not right it won't spool till your revving the nuts off it.
Bullshit......
