st3r3otyp3
Donating Member
- Feb 13, 2008
- 2,006
- 21
- 38
- Location
- Perth
- VX HSV VX SS
all the CAI you guys are making are nothing more than a water injection ram if and when you hit a puddle..
and if you hit a puddle and ram water into the engine...and have try and run on it...it blow the engine apart....
place your air ram CAI above or equal to engines air intake on the engine !
get it as close as possible
get it filtered
get it breathing fresh air
sniffing the air on bottom of the tar road....is sad...
you get better outcomes from night time air --- cool air with the boonet off and holes drilled into the top of air cleaner with mini air ram..snorke fitted to direct forced air flow
and if you have a lowered spring lowered shocker front end it be worse....so low 1inch extra low 2inch or wild and mad low 3 inch...your ground to sniffer height is too low...
you also dont understand the term or words ...""dusted engine"" or look in your car owners manual under adverse conditions
sniffing the crap up along the road that your car vortex will create a vac....and udst and dirt will in going in big time!
even finer parts the filtered was ment for...
the filter where it is fitted now has taken in to account travel dust weight...etc...and just 1 leak in a standard air cleaner and you dust the engine
which means sandblast insides..meaning major dollars for a rebuild..
so air ramming increases your risk factor...
and vac air ramming doubles that risk again !
hence why real makers dont wish to sued...and thus fit wht you consider expensive tested CAI for cars
NOT bunnings super specail budget plumbing fittings...
Mess with a spare bonnet and making air ram scoops and vents.....and stuff....
hope this helps you...
Not been to much of a smart ass but:rofl2:
