Car wont crank after neon install
astra1385
39
Strathmore
2015 holden astra cd
My car wont crank with a good battery and check engine lights all come on with ignition on.
Possible short curcuit, faulty relay, or computer and impbilzer.
Problem occurred straight after I tried to install neon lights to my car wiring a live wire straight from positive battery terminal through fire wall to a switch. Then I earth the switch from a bolt connected to the chasing in the middle console and the neon positive to the switch acc terminal once complete I connectednthe battery and there was a light spark to the ground terminal didn't think anything of it abd then went to switch the car on and switched on and off the installed neon switch and nothing worked so I tried to start the car to find it won't crank over. I tried to bridge the starter relay and it'll just turn over but wontbstart.
Need help or someone in melbourne around pascoevale area no of a good auto. Mechanic I van take to
