Catch can?
Benny304355
svz wagon
hi everyone I'm trying to work out what I'm meant to do with a catch can do I hook up both sides to the in hose part of the can or just the bad pcv sid sorry I'm not to good with naming the things I've got a bad brain injury so I am trying to make sense so I can get some help to get it done thanks in advance
Benny304355
svz wagon
Sorry I forgot to mention that I am going to put it on my vz v6
Benny304355
svz wagon
Ideally you only connect it between the PCV and the throttle body.
Before even considering a catch can, do the PCV mod and you won’t even need a catch can.
https://forums.justcommodores.com.au/threads/vz-and-ve-alloytec-pcv-problem-fix.279039/
Yeah I was thinking I should try that first I just bought a new pcv for it so I've been doing a lot of YouTube searching and I thought I'd just ask on here because it's my first vz I've always had ecotecs so I've been stressing cause I didn't really know much about alloytecs and I got it cause it was cheap and 5 years newer than my vx ya know thanks mate
Fu Manchu
WA.
Not all new pcvs are of the appropriate size so check first.
Benny304355
svz wagon
Oh OK cheers what size is it meant to be I've seen a couple of different things and most of the ones on YouTube were american and that
Benny304355
svz wagon
Na all g I looked it up 3 ml an 2ml thanks again
Fu Manchu
WA.
Read post #3
