85berlina
- Jun 27, 2006
- 137
- 3
- 0
- Location
- Sydney
- VK berlina sedan 202
Oh, now I understand why you keep asking. Thats fine.
The 12v going to the ACC wire and the imobilisor relays MUST NOT fall to zero when cranking. If it falls to zero, it menas the relay will turn off when you crank and immobilse the engine again.
About your main 12v wire that you installed coming through the fire wall, that is exactly what I did and it will do the job fine just as long as the wire is large enough to take the devices. I have used 25 amp rated cable which is a 12 gauge cable. It is about 5-6mm diameter across the copper part. This is probably a bit overkill and I used it because I had some off cuts laying around so the chances are, you are fine. If you are using thin hookup wire, such as 1-2mm cable, it will be too thin.
The starter motor solonoid gets 12v of power only when the engine is cranked, so I would suggest not tapping into this. You should use one that goes to 12v when the ignition is turned on and when the engine cranks. You are talking about tapping into this and connecting the ACC wire, right?
You should try and tap into power rails inside the vehicle. You will probably need the battery connected to find one though. This makes it harder for thieves to pinch your ride, remembering that commodores are easy as to pinch.
Pin 30 on the fuel pump relay should probably be connected to a source that goes 12v when the ignition is on, it also can't drop to zero when the engine cranks.
Once again, just remeber that pin 86 on the immobilisor relay can't fall to zero volts when the engine cranks because it will immobilise the engine when you crank.
Other than that, your pin outs look fine.
