Checking error codes VT/VX
Fitzy09
Frankston
Vt Berlina 1998 Not my dp
thanks much appreciated
K Lewy
Sale, Vic 3850
3.8L 1997 VT S Pack; 5 Spd Man
I cant find the thing to bridge, picture be appreciated
anarklov3r
2007 WM Caprice
its just above your pedals, not under the steering column cover(where the fuses are) look further down.
best way to explain where it is, is to put your head on the floor, face upwards and its there.
Logz10
VH SS
What code do you call this flash sequence:
2, 10, 1, 2, 10, 10, 1, 2 long-pause 10,10,1,2 long-pause 10,10,1,2 long pause, 10,10,1,2 ?
link to video
I gather the 1,2 is code 12, but what are the others?
Apparently VX II and VY have four digit error codes (see this thread http://forums.justcommodores.com.au/vt-vx-holden-commodore-1997-2002/43612-vx-fault-codes.html)
If can't find a list to see if there is any difference between VT/VX to VXII/VY error codes so should I assume they are the same?
bovered79
VX HBD
vx berlina Problem please help!!
I have a vx berlina and i have started getting starting issues, and last night i had the heater going on and off by itself anf the check engine light coming on then off head light dimming airbag light coming on and off etc. Is this a ECU error ot what could it be and is it easy fixed can i just replace the ecu with a 2nd hand one or does things need to be reset can anyone help thanks
ratz26
worlds oldest noob
tweed heads
2001 VT equipe
for those that asked this is where u bridge.
on my 99 VT its on the bottom of the fuse box door thingy right above the brake pedal
Mirkz
WA
GSXR1000
Thanks for this!
Just checked mine after seeing my check engine light coming on twice this evening just as I got in the car to come home.
Started the car, engine light on, turn it off, started again, engine light on, then eventually went.
Seems Mine's gone to code 15 which is coolant temp sensor voltage too high.
Random...
Was only flashing that code and the standard 12 code.
Logic
Ohope Beach New Zealand
99 5.0L V8 VT Berlina (Modified)
Dont forget that the engine light can come on for simple things that mean nothing. For example when driving slowly with a big-bore exhaust, the headders are too cold for the oxygen sensors to work correctly and will return an error.
Davidcurley
VT Acclaim
Thanks for that I will try them out tomorrow morning. Is there any way I can check the ABS module?
FalconTop
iraq
vx/ 2001
Mine got 10 flashes then 1 repeatedly that's all, what does it mean Please.
