luminex
- Sep 3, 2007
- 187
- 0
- 0
- VX Lumina
Hey bud, love the car. It looks awesome. Ive always loved red! Hey just a quick questions, what did you use for around the screen, cos i put some gauges in but need to blend it in. Keep up the good work, and more pics :yeah:
cheers mate, around the screen i used the origional surround that came with the headunit, wish i had more pics to explain but there was a big gap on the bottom and the left hand side, but the top and right were touching the dash so i glued these 2 sides straight to the dash while it was all in the car so the positioning would be right, then i removed the dash and used plasti-bond (Got it from Mitre-10 white box) is real easy, just mix with the hardener and spread it on, very similar to bog.
had to build up the gaps which was hard, then sanded it alot to blend with the curves.
ended up using a bit of bog in the bottom corners. also, along the way i used a spray putty primer it is a really thick primer which fills in any little holes or scratches which there was alot of. then yea, not its all putty primed and sanded so its real smooth and awaiting paint to arrive n yea thats bout it.
i used a finishing sander and mostly 400 paper seemed to work good, it took me 2 whole days to get to here though so allow yourself a fair bit of time!
Good luck mate n cant wait to see how yours turns out
