RevNev
- Dec 9, 2020
- 2,636
- 3,605
- 113
- Location
- Adelaide
- VF II SSV Redline Ute
Needing a hit to satisfy my 40+ year serious addiction to tampering with cars meaning any car of mine can't remain stock, I'm in the process of giving my recently acquired MY16 SV6 wagon a subtle tweak. Being raised with the idea that you're a bit of wan%$r trying to make an SV6 look like an SSV Redline, the car will retain the SV6 look but a better version of the SV6 in appearance and drivability.
405mm from the centre of the wheel to the guard is no good (overlander style), so I've fitted King SL's in the front and RLHD's in the rear that moderately lowers a V6 25mm reducing the ride heights to 380mm. Particularly in the front end, the lower control arm and radius rod bolts are tightened at stock ride heights and when lowering the ride heights, the bushes distort. Consequently, I "always" loosen the bolts at the revised ride heights when lowering a VF that's a relatively simple and essential process that I don't see many do that often and they should particularly suspension specialists for most part are too lazy and can't be bothered!
Even lowing the car only 25mm and loosening the lower control arm and radius bolts, I could hear the bushes "twang" into their revised clock location and the bushes rotated 5 or 6mm from their stock ride height position. Here are the bolts (pictured below) that need to be loosened and retightened, and you'd be surprised how far the bushes move to eliminate distortion from lowered ride heights.
