well done :) u was on to it from the start :)
G graham7773 Active Member Joined Oct 6, 2008 Messages 1,053 Reaction score 19 Points 38 Members Ride VT Acclaim Wagon Sep 4, 2015 #12 dirty hands, you done it again. Remove starter to inspect it, problem found and solved! New starter motor. Promotec, glad your problem is solved
Tsunamix Active Member Joined Nov 17, 2008 Messages 666 Reaction score 32 Points 28 Members Ride VT 2 Sep 4, 2015 #13 Have had similar noises in the VT before, but a different cause. The Relay on the top of the starter can jam closed. Often a tap frees it. Usually occurs after a high current event, leaving some micro welding going on in the relay.
