few suggestions
hi, better late than never but i have a few suggestions (given my old man, me and brother have vn/vp's)..
from our experience, while the front end of the car is jacked up... if you can shake the wheel vertically (hand on top and bottom of wheel, push one, pull one) then its the balljoints...
if you can shake wheel side to side (hand on sides, push on one, pull on other.) then its either tie rod ends or rack ends (rack end screws all the way into steering rack, it also includes the tie rod end in it... each one $30ish?)
if you can hear a metallic noise when you go over a lump, we found that to be the part when the stabiliser bar is connected to the strut i suppose... it has a bolt, 2 or 4 rubbers and 4 concave washers for each side...and the rubbers had virtually disintegrated... so that was an easy fix as well...
now another thing i had was the same as yours, you mention a clunk when you go around a corner one way, well, it took us ages to find but at the top of the strut where you screw a bit octagonal or hexagonal nut onto the strut... mine came loose and the strut could physically move...
now you dont need to take the whole strut out to fix this, if you reach in, clip off the cable tie that stops rubber boot inside sliding around you can reach in with a big wrench and tighten it up (its supposed to be locktited)...
anyway, hope this helps... if it does help then please just give us a yell so i can feel usefull for once
lol
Adam.
