damiandownie
Damo (Vl Walky replica)
- Feb 3, 2008
- 23
- 0
- 0
- VT V6 commy
Hey guys i have just recently gone through the same problem with my vt s pac supercharged not shuagh if its the same as vs but one way to check if the wiring is all ok is that you unplug the connector to the thermo fan sensor and turn the ignition on the low speed fan should kick in after 6 sec anf then high speed should kick in after 12 sec if that happen wiring and realys are fine ,my problem was that once the sensor turn the fans on they wouldnt switch them off so i replaced the sensor which is usually around $113.00 from holden they are the cheapest around burson $134.00 but i paid $64 for my sensor bcause they said it christmas wel thanks holden and that fix my problem and fans are turning on and off now so hope this helps .
Sorry to dig up an old post but where abouts is the thermo fan sensor wiring? i have already replaced the relay with 3 brand new ones from 3 different places and i still have code 92
regards damian downie
