Conversion from auto to manual Vr V6
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by braca1975, Oct 11, 2004.
  1. braca1975
    braca1975 Guest
    Hi all
    Just wondering I just did a auto to manual conversion on my V6 beast and was wondering if the wiring of the automatic transmission will effect the performance of the engine or anything else on the car. If so can i bypass the wiring, also is that the reason that the thermo fans are constantly on. Please help me :hit:
  2. Doctor Bob
    Doctor Bob Grandpa
    Mornington Peninsula
    VT V6 Exec & VN V6 Exec
    try doing a search on here for conversion , you should get plenty of info on your swap.
    the engine fans are on because of the wiring yes, you will need to make sure you have a speed sensor connected to your manual trans & contact me for a conversion memcal to eliminate the codes for the transmission, a few of the guys on here have done this & are very happy with the results
    Cheers Rob
  3. Troy711
    Troy711 Retired Old Fart
    Canberra, ACT
    2011 Mitsubishi Pajero GLS
    hey bob, good to see that your reputation points are going up. you are getting the credit you deserve for being so helpful!
  4. TAILS83
    TAILS83 New Member
    Brisbane northside
    VZ SS
    just rewire the auto loom it will take you about an hour to work out where the wires go, use a gregeries manual and then about an hour to change the pins on the computer connector
    use a vn computer if you can't find a vr v6 manual one, i have one spare but if you want to pay me almost what i paid then u can buy it off me
    i'm still running a vn computer as it works and i got no problems with it.
    u also have to wire in a pulse divider into the loom which will require 4 hirw hook up, they can be found in the back of a vn instrument cluster.
    if you want more helpjust pm me i'd be happy to help, i've done a few converions.
  5. Lyoness
    Lyoness New Member
    Western Australia
    VX SS 5.7 M6
    Hi,
    just wondering, I've always wanted to convert my auto vr series 2 to manual but was unsure of what I needed to change.
    I was told i would need a new gearbox (obviously), drive line & shaft but was unsure about anything else i need plus I was told i would need a manual computer as i wouldn't be able to use my auto one.
    HELP!!!
  6. Doctor Bob
    Doctor Bob Grandpa
    Cheers Rob
  7. Spanner
    Spanner New Member
    I have read about this sorta stuff before, and the main comment that i keep coming across is that it is cheaper to buy a manual commodore than to convert.
    By the time you get the pedal box, wiring looms, dash panels, gearbox itself and so on, unless you can do all of it yourself it is going to cost a shit load
    But then again it is up to you...
  8. Lyoness
    Lyoness New Member
    Western Australia
    VX SS 5.7 M6
    I did a quick search on manual conversions and their are some really excellent treads about them, reckon you give them a read, will heaps you out heaps.
  9. VSst8o
    VSst8o New Member
    vs statesman III
    hi.. does anyone no if the cranks an flywheels are different on the vs-vt?? iv'e got a series 3 vs stato 1999 im pretty sure it has the vt motor n box.. can anyone help me?
  10. deanos70
    deanos70 Member
