houdini_007
- Oct 17, 2006
- 29
- 1
- 0
- VE (V-Series) Omega with alloy wheels & rear spoil
I apologise in advance if this is going to be a stupid question ...
I have a 2006 Omega (V-Series) and noticed coolant leaking from the waterpump. I could not see where exactly as the pully is in the way. I know the coolant resevoir tank was way above the full level and with all the leaking it sort of went down to the exact Full level. The leak has since stopped (after buying a new waterpump, read to change it over) and I am just wondering;
1. Is there a drain hole or something on the water pump
2. I would have though the level in the resevoir would not really matter if over filled. Is this co-incicdence that the leak stopped at the same time the coolant got to the correct level in the reservoir ?
Looking forward to your replies .. THank you.
