[VIC] could a vy/vz boot go on vt/vx???
dzach23
Bra Bra Potato Potato
VX Lumina Series 1 genesis blue
More curious then actually interested in doing this,
but could a vy/vz boot go on a vt/vx?
I know the shape of the boots are different but would the boot still seal shut,
I would be interesting to see what it looked like... all opinions welcome...
dzach23
Have you even tried placing one on?
just a thought on getting a different looking lip spoiler...
HamaTime™
VIP Member
C Class AMG
Why don't you put a Volkswagen Beetle Bonnet on while your at it?
Sorry to kill your idea but what on earth made you think that a square boot would look good on a bulbous shaped car with very 'round' lines...
dzach23
i know changing boots won't look good. i was more interested to whether it would actually change over and still function as a boot.
HamaTime™
VIP Member
C Class AMG
You could make it fit...you can make anything fit...but will it be appropriate? Will it look good? I think not.
dzach23
I don't care what it look's like or whether it will be appropriate I was just wondering
if it would fit/function normally being that the vy/vz is basically structurally the same as the vt/vx.
I don't have access or am familiar with vy/vz boot otherwise I wouldn't have asked.
(I'm just thinking outside the square)
GAMBLR
More trouble than u think
Whyalla (yawn), South Australia
'04 VZ Calais LS1
Direct swap over? I have serious doubts, due to the angles and general shape.
If you want a lip spoiler, look for a VT HBD spoiler or VT Manta.
EDIT. I have a VZ. Dad has a VT. Realisitcally it won't fit properly or seal correctly
anarklov3r
2007 WM Caprice
To answer the OP's question, I think it should fit since the shells of the car are the same. Only problem i can see you hacing is that you might actually hit the rear quarter panels. Ive seen somebody put a VZ boot on a VT, and replace the quarter panels with VZ ones and it worked. No idea on how much they had to modify.
if you know somebody with a VY/VZ, put cars together, pop boots and compare. They should be the same.
