Justbadger
- Jun 7, 2021
- 47
- 3
- 8
- Age
- 36
- Location
- Mount druitt
- Vt calais v6
What began with replacing the balancer turned into fitting a performance timing chain set from crow cams the crankshaft sprocket so snug it began pushing the keyway in with it I stopped n had to tap it all the way back off.. to find the little tab bit on the end had bend upwards slightly.. in my wisdom I grabbed the shifter fitted it on there n tried to bend it back thus snapping the tooth off. It's back together now n seems fine havnt started it yet do ya think I'm gunna have drama there was still a lot of keyway in the balancer shaft so I'm assuming it should be fine???
