Crewman Clutch Problem
Crew Man
69
Thornlands QLD
VZ Crewman SSZ
Just replaced the clutch in my VZ SSZ Crewman. Put in a heavy duty as I tow a caravan and put in a new thrust/slave. Had trouble getting enough pedal, even after sucking/bleeding all the old fluid through. Replaced master cylinder, still have the same problem. Is it because I need a heavy duty master if there is such a part? I have the pedal up as high as it will go to get maximum travel. Thoughts please.
