[LS1] Decking the block
MiKExAUS
Sydney NSW
VX SS A4 Series II
After pulling the heads to inspect and replace my lifters I've managed to put a few gouges in my block when cleaning up the deck with a razor blade ready for a new head gasket. I'm hoping the viton parts of the new gasket fill the troughs and block any coolant leaks. I'm thinking I should sand the deck to remove any high spots too. Keen to hear how other people have done it and if they think I need any other interventions ie JB weld.
Thank you!
shane_3800
35
places
vr commo
You should give it a very slight rub with sand paper on a 100% flat block every time.
If you're that worried just buy some MLS gasket spray.
MiKExAUS
Sydney NSW
VX SS A4 Series II
Thanks Shane. Sounds like a good idea to remove any potential high spots. Any particular grit range recommended as I thought the MLs gaskets require quite a smooth surface.
hademall
Donating Member
66
VF CALAIS WAGON
Fine grade sand paper?
shane_3800
35
places
vr commo
400 or 600 should be good, 800 won't do much.
shane_3800
35
places
vr commo
Great. Would you also recommend doing this to the head deck if i'm not having it machined?
Yes. But like I said it only needs a few rubs.
MiKExAUS
Sydney NSW
VX SS A4 Series II
Can you recommend any store items for a 100% flat bar? Would a honing stone or sharpening stone from Repco/bunnings be dead flat? Otherwise I guess I'll have to call around to some machine shops
lmoengnr
Donating Member
Sunbury Vic.
MY12.5 Maloo R8, MY12 Redline ute, Magnum 224
Go to a glazier and get a piece of plate glass cut to suit the paper you're using. Wear gloves.
  • Like
Reactions: Lex
shane_3800
35
places
vr commo
No those stones are bent like bananas.
