Diff gear Question
Discussion in 'VZ Holden Commodore (2004 - 2006)' started by jwaye2, Aug 22, 2012.
  1. jwaye2
    jwaye2 New Member
    Darwin
    VZ Alloytec Sedan, VS L67 Ute
    Does anyone know what the diff ratio is in the standard VZ Exec sedan v6 auto? Wanna put an LSD diff in it and not sure weather to keep the same ration or change it.
    If i end up changing what should i change it to? not building a race car just wanna give it a bit more of a kick.
    Sorry dont know much about diffs
    cheers james
  2. richardpalinkas
    richardpalinkas Blown Alloytec
    Gold Coast
    Raptor Impulse VZ SV6
    Standard is 3.08:1, a good upgrade is the 3.46:1 ratio usually found in manual ss commodores so it should be fairly easy to find one
  3. Surfwagon
    Surfwagon Active Member
    Sydney/NSW
    HSV VZ LS2 Senator
    There is usually a few LSD 3.46's floating around on ebay at any one time and most are LSD as they come out of V8's, HSV and SS's.
    3.46 is probably the best ratio for a stock to lightly modified V6 as it gives it kick without really hurting fuel ecomomy, in fact around town it usually gets better once you stop enjoying the new found squirt.
    Highway fuel economy stays pretty much the same.
  4. morphix
    morphix New Member
    Cardiff, NSW
    2004 VZ SV6 5-Speed Auto
    What are the rev differences between stock and 3.46? And how much does it affect acceleration?
  5. richardpalinkas
    Gold Coast
    My 1/4 mile changed by .2 seconds, but 0-100 was about half a sec quicker, that's with an sv6
  6. BPX-31H
    BPX-31H New Member
    '05 vz sv6
    When you changed your diff who recalibrated your speedo or how'd you do it?
  7. Surfwagon
    Sydney/NSW
    HSV VZ LS2 Senator
    At 100kph difference is about 200 revs more with 3.46 and you will notice the extra punch from the 3.46's.
  8. jwaye2
    jwaye2 New Member
    Darwin
    I know the computer will have to be calibrated but if i replace a 3.08:1 with a 3.46:1 will it bolt straight in or will some things have to be changed to make it fit?
  9. Surfwagon
    Sydney/NSW
    HSV VZ LS2 Senator
  10. richardpalinkas
    Gold Coast
    I took my car to Holden and they recalibrated it for 60 bux
  11. djbrentos
    djbrentos New Member
    sunshine coast
    vs 5lt stato
    does this mean when i change my vs vtatesman 5lt diff over to a lsd form a 6lt ls2 will i have to get the cpu recalibrated?
