As Follows:
* Remove the screws along the bottom of the speaker pod
* Remove the little bit of plastic in the centre of the door handle
* Remove the 2 screws retaining the door handle and remove the door handle
* Remove the air vents (still dont really know an easy way to do this... just pry with a flat blade screwdriver with a cloth over it so you don't scratch your trim)
* Remove the screws retaining the air vent holder thingy and remove it.
* Using a little piece of stiff wire with a tiny little hook on one end, pull the red tab on the door lock towards you and lift the lock off the control rod
* Using either a rag and a lot of cuss words or a tool you can buy from supercheap for $10 to remove the window winders. If you peer behind the handle you will find that the winders are held on with a spring clip in the shape of the 'ohm' symbol. In my opinion it is 10,000 times easier to just go to supercheap and buy the window winder removal tool.
* Unless I've forgotten something, you can now give the trim a firm pull and it will come away from the door.
Sounds harder than it is
just give it a try.
