Dyno Sheets
ari666
250,000 hits
It's actually really disappointing to those of us who don't know all the technical mumbo jumbo, and get duped by either lazy, lying or incompetent operators.
depends on what you mean by "duped" buddy. if youre AFR is a nice straight and true line, then your tuner has done his job and thats the end of it.
if you wanted a piece of paper saying you had six billionty-watts, then yeah, you got duped.
christov
RFFN RFFR
VF Redline, BMW M4 Coupe, Harley V-Rod
I think you've misinterpreted mate, or I haven't been clear enough. Never said anything about wanting a sheet saying I have lots of killerwasps, purely interested in the true gain from mods done and not interested in seeing a figure that is far too high. If you refer to Grennans post about 270+rwkw cars with just an exhaust, intake and tune you will get my drift.
Deuce
Super Stock
'94 VR SS V8
3rd run on the Dyno:
Deuce / Mike / VR SS
HP (279.1hp), kW (208.2rwkW) Over 600Nm @ rear wheels
Engine Type and Capacity: 5.8ltr V8 - VN block
Power Adders: Same top end, exhaust and intake as previous Dyno, but now with: Eagle 3.48" crank, 5.7 H-beam rods, ARP rod bolts & head studs, 19cc cast pistons +.030", Cometic .027 MLS head gaskets (~9.3:1 Compression), Crow 4502 cam & lifters, Crow BBF Valve Springs (shimmed even), Miloden 308 windage tray (modified) and SBC mounting studs. TK383 spec modified oil pump (JP std vol), further mods and coatings to stock intake manifold, reconed 36lb Super6 injectors from Mace, Powerbond balancer. Immortality Tune.
Trans Type: M30/4L60E (Kitted & cooled)
Diff Ratio: GU4/3.08
Wheel/Tyre size: 245/45-17
Fuel Type: Caltex 95 Tecron
Name Of Workshop: TeRapa Automotive
Date Dynoed: 12/12/14
(note red curve from last engine is plotted on bottom km/h scale, where new engine blue curve is plotted on top rpm scale, I have written on reference points to help.)
I've got at least another 300rpm on this combo over the old engine, more torque everywhere and possibly issues with fuel supply holding us back. So will be working through that and taking it back some time next year, because this seems to be getting a Dyno run every year now, LOL
Re-run with a new fuel filter:
AFR is down around 15.1:1 max now. Tune still needs work though.
I've picked up a good 15Nm through the early-mid range. But max output still sits around the same. (ignore the spike at the end where the Dyno backs off and throws false figures for a second)
Still can't work out why the old graph goes to a higher km/h with less rpm, unless it ran on into the next gear or something. Blue and Green runs were to roughly 6000rpm.
Kiddo
You're serious bro?!
Mitsubishi Colt
From my little 1.5ltr
WHERE IS YOUR GOD NOW MUAHAHAHAHAHA
AirStrike
91' VN SS
Where the hell is the inlet!? 8 degree variance.
Brisbarnz
Vh sle
Finally got the vh on a dyno. Std vn304 with a h268, 200i tune.
mark_1000
2005 VZ Clubsport
VZ Clubsport LS2. 4-1 Pacemakers, 200 cell cats, twin 3" manta exhaust, VCM Plastic OTR, tune.
crazybiker
Sydney NSW
VR Commodore V6
VF SSV Redline Ute. Series 1
375hp, 279.9kW
6L L77
Power Adders:
- DiFilippo 1 3/4" Headers with DiFilippo 2.5" ehxuast finished with Varex Mufflers
- VCM OTR
- Tune by Autowerks
Trans Type: 6 Speed Manual (TR6060 I think?)
Diff Ratio: 3.45 (Again, I think. Standard)
Wheel/Tyre size: Standard. 275/35R19
Fuel Type: BP 98
Name Of Workshop: Sonny @ Autowerks Automotive in Beverly Hills, Sydney
Date Dynoed: 4/12/15
Overall, I'm quite happy with it. Throttle response is much improved. It has a lot more pull throughout the rev range, especially off idle.
'ssv'
41
VE SSV MY9.5 M6 UTE
Series 1 so 6 litre vf?
280rwk seems a little high for the usual zorst/intake/tune. I wonder whats changed.....
Bet it sounds nice...
