eBay Chinese fuel injectors - warning
shadetreemechanic
perth
VR v6
G'day all,
Well I wanted to get some new standard fuel injectors recently and I saw them going for about $170 a set on eBay. Knowing that they sell for $80 each OEM new old stock (Bosch in this case) it got me researching.
Turns out that anyone can hit up any of a number of Chinese factories that claim to be able to pump these things out at a rate of 100,000 per month and sell em for as little as $1 a pop. That's exactly what the eBay sellers are doing...
For proof look at Manufacturers, Suppliers, Exporters & Importers from the world's largest online B2B marketplace-Alibaba.com
Do yourselves a favour and find a workshop with an ASNU ultrasonic cleaner and service your original quality Bosch/Denso/Siemens/whatever injectors instead of throwing them away in favour of who knows what cheapo rubbish.
nes138
Gippsland Victoria
FC HOLDEN with 5LT V8 (VT)
Nup they are the best quality. Isn't that why Holden are making commodore from there as well???
AirStrike
91' VN SS
I don't understand this thread, is it warning us that cheap **** Chinese injectors are cheap **** Chinese injectors?
ari666
250,000 hits
someone just found alibaba
VTSSLS1
brisbane
VT SS LS1 A4 227rwkw
Any ultrasonic cleaning machine can be used on these, the main thing is that the correct fluid is used. There is specific ultrasonic injector cleaning fluid, which is very strong stuff. Also you need to be careful with how long you run the injectors for in the fluid, or it can cause the valves to stick. Likewise leaving them out of the car for longer than a few days after cleaning, they can stick/seize and be worthless. And you need to make sure there is none of the cleaning fluid left in the injector before putting them in the car, the best way to do this is a flow machine, but failing this you could thoroughly clean them with carby cleaner.
delcowizzid
on holiday
NZ
в∞ѕтεכ √&
i buy all my injectors off ebay or aliexpress LOL only ever had 1 dud injector that was stuck open.going 11.1 on ebay seimens dekas that cost 300ish for a set sure beat the $120 each over here LOL
Munz
Right Foot Action
Brisbane NTH
VZ Calais LS1 / VL RB30e daily
These days all injectors are probably made in china......
Pollushon
Boost gives me a bar....
VY SS
Just like my DBA rotors and Bendix pads. Chinese made doesn't make something ****, Chinese knocked off, usually does.
