Ecotec idles fine until booted
brandonev111
Dandenong
Vx Commodore S2 ecotec
Hey guys I have a 02 vx Ecotec and on startup and normal driving it idles fine sounds perfect but after giving it a boot it will idle really roughly and stay rough until I turn it off and back on. Anyone got any explanations? Checked and cleaned maf, throttle body, air filter, spark plugs, leads. Just curious, cheers
Immortality
Staff member
Sth Auck, NZ
What did the plugs look like? all 6 look identical or was there a couple of odd ones? What is the plug gap?
Could also be a fuel pressure/flow issue, when was the fuel filter changed last? Tested fuel pressure?
brandonev111
Dandenong
5 plugs identical, about a year old, 1 brand new coz it was snapped. Fuel filter replaced a year ago. Haven't tested pressure but it seems to be fine, pump was also replaced when filter replaced.
brandonev111
Dandenong
The plugs tips were all white which means running rich right?
Forcedvp
VT HSV XU8, FORD TERRORIST
Immortality
Staff member
Sth Auck, NZ
No. White is lean. But these cars use lean cruise so very clean plugs isn't out of the norm. Black is normally rich. But really need to see them to be able to judge what they are suggesting.
Where is the new pump from? Cheap ebay? Test fuel pressure.
brandonev111
Dandenong
Ill try and take a photo of plugs this Arvo. And pump was from Repco, will try and get pressure tested
