Engine number
Chris1989
45
Vn ss, Vh sle
I have a blue 308 an was wondering if it’s possible to tell what car the motor came from originally by the engine number as it’s not original motor from my Vh
SL/ENUT
The SL/E Fanatic!
41
Burnie, Tasmania
VB SL/E 5L
Sorta can. Whats the engine number? Also whats the cast date, its above the water pump.
Bigfella237
Far South Coast of NSW
More cars than I've got space to park!
It should be an early small valve 308 blue motor from either a VC Commodore or a WB commercial (not a Statesman). There's no way to tell which.
If it's an Aussie bolt pattern block (to bellhousing) then it came from a manual (M21 gearbox) vehicle, or if it's a Chev bolt pattern it was an auto (TH350). If auto, I'd think it would more likely be from a Commodore, but that's just a guess.
Cast date would be 9th of October 1980
Bigfella237
~ late vc and early vh motors
Except the VH wasn't released until September 1981, so an October 1980 cast block is unlikely to have sat around for 11 months to find it's way into a VH.
Stranger things have happened though!
@Chris1989, I was just re-checking my notes and they say that blue motors which went into WB commercial vehicles at that time had "WT" prefixes for the 308, so that removes that possibility, meaning your motor must have come from a VC Commodore.
Andrew
gtrboyy
vt ss & lc gtr
If it's vh sle most likely was 253 like majority of them....vt prefix is enough to keep most content when 5 litre upgrade goes in.
Chris1989
45
Vn ss, Vh sle
Hey Ive done a bit more looking an have come across a B welded on the heads a hsv stamped on them, what does this mean?
Any help would be appreciated
Smitty
Moderator
Bayside Melbourne
GenF SV340 R8 Tourer, VK race car, ZX12R
B scratched in the casting of the heads... with a HSV stamp?
hmmm...simply not possible me thinks! the last B cast heads was VK Commodore hipo engines (several .. A9L etc)
but
HSV did not exist then.
HSV started after VL came out and the VL V8 carby heads (used on their first car - SV88) did not have anything scratched in them
(only the part no between rocker cover rails)
Chris1989
45
Vn ss, Vh sle
but
Looks like hsv stamped on top of head nest to brake booster could have more written but without taking of the rocker cover to have really good look
Also looks to have a B welded behind the alternator on the head
Confused
