vr_calais
- May 8, 2004
- 28
- 0
- 0
- Age
- 58
- Location
- colyton nsw
- vr calais v6
thanks fitzy2005 i will check it out
also check m.a.p. sensor vacuum hose on firewallChRiDDa said:the oxy sensor has died as a result of the fuel pressure regulator being knackered
remember, the oxy sensor does NOT work till the temp hits around 380 degrees, so that wouldnt be the cause of his black smoke at startup
the cause is the diaphram inside the regulator has given up the ghost
this causes the car to become flooded, and is why your oxy sensor is dead, because its been coated in unburnt fuel
hope this helps!
