Entire dasboard out including radio and clock on ve , ?
Jasont
2008 ve commodore
I done a silly thing and put in battery in while ignition on, now whole dash and radio out, electronic key won't work either?? Help
Jasont
2008 ve commodore
I pulled some out and checked, no blown fuses. There is no lights on dash, speedo or gauges, radio or air cond. electronic entry won't work either. Lights on steering wheel do come on though and windows work
Goldstorm100
2013 VE SSZ Ute
Disconnect battery for about 10 minutes, then reconnect with everything off. If not try locking and unlocking the doors 10 times it seems to do a hard reset of the computer on most cars. Good luck, let know how you went
Nut Kracker
Donating Member
64
Echuca Vic.
VT SS 304ci (195i)
Check fusible links???
Tasmaniak
Not a valid input....
41
S.E. Melbourne
www.ranjinstallations.com.au
Check them all. When some systems initially power up they can pull a lot of current.. So when they all start at once.... it's not uncommon for one to go. Also check the main fuses.
Jasont
2008 ve commodore
Nothing seems to be working, all fuses Iv pulled are fine, disconnected battery over night aswell
Nut Kracker
Donating Member
64
Echuca Vic.
VT SS 304ci (195i)
May be fried the BCM :hmmm: :bomb:
Jasont
2008 ve commodore
Anyway of checking that? Looks like its def blown or fried something
Nut Kracker
Donating Member
64
Echuca Vic.
VT SS 304ci (195i)
You would probably have to take it some where and get it plugged into a computer.
Or take it out, open it up and see if there is any physical damage, burn marks etc.
