Fault codes vs executive v6
maddhatter44
30
Mount barker
Vs executive series 2
Hey I recently got a vs commodore executive after finally learning how to to do the wire bridging to get fault codes this is what it’s throwing out
13: rh oxy sensor
15 coolant temp high voltage
16 () unstable voltage
23 mass air temp sensor high voltage
63 l/h oxy sensor no signal
any ideas weather to replace the sensors or if it’s a wiring thing please just so ya know I’m a young single mum so please when trying to assist use dumbed down talk lol
lout
60
Langwarrin Victoria
welcome to JC
as you dont know how old those codes are
disconnect your battery for 1/2 hour to clear the codes
you will need radio pin number if stock headunit
or you can pull the ecu fuse, but i dont know which one it is
then see what codes come back
maddhatter44
30
Mount barker
welcome to JC
Was surprisingly able to work out I needed to do that so these codes are after that:)
lout
60
Langwarrin Victoria
start looking for bad grounds
krusing
Melbourne, Bayside
Check your standing battery Voltage,
And your charge voltage also.
losh1971
North Tas
VE Series I SS Ute
The VS has a common problem with bad grounds for the 02 sensors. There is a sticky thread that mentions the fix. If they are still an issue after that then grab new NGK ones from Repco, if they have them, otherwise see what else they have. Whatever you do don't buy an O2 sensor from eBay.
gtrboyy
vt ss & lc gtr
If it were a v8 100% would say single earth wire in harness is common link in those items up at back of head but I know v6 models lol
maddhatter44
30
Mount barker
Probably a blonde question but if it’s evident there is a misfire would the be a misfire code or possibly cause by one of these codes
lout
60
Langwarrin Victoria
dont think vs was modern enough for misfire codes
with a high end scan tool could probably do a cylinder balance test
maddhatter44
30
Mount barker
So if there was a misfire could it come up these codes or visa versa
