Firing order for V6 VR
Aimee
Casterton
VR
Hi
I think I have my leads wrong anyne know the order?
Jxfwsf
Aus
commodore
1 6 5 4 3 2 is the firing order
No1 is the front passenger side
1 3 5 are on the passenger side
2 4 6 drivers side
Front
1 2
3 4
5 6
Back
aussie4life
Keep It Simple Stupid
South Australia
2010 VE International 3.0L
if it has the 3 coil packs like mine it is all electronically controlled. the only thing you can do wrong is to put the wrong leads on the wrong plugs. i will find you a image of the plug order
Aimee
Casterton
VR
Ok this might sound stupid but can you type it as coil pack number to plug number (c1 to p5) thanks
LS1 James
Donates His Member
39
Andrews Farm, SA
VT II GEN3 V8 Wagz
Errr...... C1 to P1, C2 to P2 etc etc etc. Coil number must match the lead numbers as posted in the image above.
aussie4life
South Australia
i believe they go as numbered, c1 to p1 and so on and so forth. as its electronically controlled the ecu selects the firing order
aussie4life
South Australia
thank god that i was right otherwise i would have had some serious trouble with my v6 cos i just replaced the leads
