lmoengnr
Donating Member
- Jan 15, 2012
- 7,021
- 46,495
- 113
- Location
- Sunbury Vic.
- MY12.5 Maloo R8, MY12 Redline ute, Magnum 224
Gotta luv Bi-Modals!
Mate I am positive that if you class your exhaust loud AF it is louder than 82db one metre from the tips. Download a DB meter, that's a portable radio in another room or an indoor human conversation. Likely you were passed because it was not specifically tested when the engine is held near 4000 rpm, then quickly backed off (crackle is louder btw).i got the 3" manta full system in mild steel from NAAF, it sounds pretty good. it's loud AF but i still passed RWC in a interstate move. it sounds mint anywhere above 2500 and produces a lot more power. i just keep a copy of the receipt for exhaust + install + OTR & tune + inspection report. that way if a cop does ever bring it up i can show them, so far i haven't needed it.
Thanks for ur thoughts people. I will keep ur offer in mind not_an_abba_fan. Now found out the hurricane set up is made of 409 s/s (but is australian made) whereas most other s/s systems are 304 (xforce sre chinese made i think). Going by a lot of web studying 304 s/s is superior and more expensive than 409. So why are hurricane etc systems dearer???
Just saying it is not up to any pre-prepared documentation to set you free, it is on-the-spot fine plus defect notice. Fine is one thing, being called in for further inspection is another...
Thanks for your insight into s/s grading abba. Much appreciated. I've decided to go for a hurricane 3" s/s catback medium sound just for now $1250 installed being done friday. Later mods maybe down the track.The truth behind stainless.
304 grade is industrial or building grade stainless, it has more nickel content but is also harder and less malleable. It is used in the building industry mostly as it looks pretty. It is not structural.
409 is exhaust grade, it has just enough nickel to prevent corrosion (it will oxidise and have a slight rusty looking appearance but it will not corrode). This grade is used because it can be shaped without losing it's strength and is flexible enough not to crack like 304. It is dearer because there is less of it made. 304 is pumped out for a multitude of applications, whereas 409 is only used for a few things, exhausts being one.
Look at the warranty period for the different grades, most 304 systems will only have 3-5 years, 409 generally has 10 years.
304 may be "superior" in looks, but that's it. It is used because it is cheaper to buy and it polishes up nicely. 409 does not. It is OK to use on the barrel of a muffler, but as far as pipe goes, 409 is actually superior.
