front strut bar bush in crossmember
markovr
62
northside brisbane
youtu.be
07vessv 94vr .04vz wgn,93vp wgn,82 vhV6 wgn 88 vn
Ive got my suspension apart and looked into a few bushes that commonly go on these front ends and got to the strutbar bush in the crossmember and wondered if there is a way of telling if it needs replacing...from the outside there doesnt seem to be anything wrong with it.
mpower
If they are out there's no point putting them back in, they aren't even expensive.
Immortality
Staff member
Sth Auck, NZ
It's rubber, rubber ages. If it's original than it's well past it's best.
markovr
62
northside brisbane
youtu.be
Trouble is even rubber ones are pretty exy and urethane ones even more ...just dont want to replace something not broken
lowandslow
NSW
V2 III Monaro
You can get Nolathane castor bushes for about $150 delivered from ebay.
mpower
not only that, now that he's pulled it all apart it will need a wheel alignment (I hope you are aware of this OP) and then they wear out in however long and then that's another wheel alignment, last I checked these are what $60-70?
markovr
62
northside brisbane
youtu.be
They affect castor and they cant be adjusted easily...what can be adjusted front end wise for wheel alignment only toe in and camber and what ever they can squeeze out of the crossmember holes by slewing the whole crossmember.
My car has never had a wheel alignment and its never worn tyres unevenly and tracks fine..... steers fine
I didnt just think one day I might pull by front end apart for fun ...its because the engine sludged up and I needed to take the sump off to clean so I had to drop the crossmember.
lowandslow
NSW
V2 III Monaro
Adjust caster by adding spacers infront and behind the bush on the Z bar.
vc commodore
Like the Leyland Brothers
VC, VH and VY
The only way really to tell if that caster bush is worn is to put it back in place....From there, grab a screw driver and lever between the washer and front K-frame and see if there is movement in the bush....Or alternatively, with a 2nd person beside the car, drive forward or back wards and brake hard, then see if the wheel moves back or forward.....
If you have no movement with either method, the bush will be fine....There will be no need for a wheel alignment, as the caster will be exactly the same, therefore the camber and toe....
Only if you replace them, would it be necessary to have an alignment done, as the caster would have changed slightly, there changed the toe slightly.
MYVESSV8
Brisbane/GoldCoast
VE 6LT M6
