Front suspension bushes
Discussion in 'VT - VX Holden Commodore (1997 - 2002)' started by Blue Gemini, Jul 30, 2005.
  1. Blue Gemini
    Blue Gemini Guest
    Its time to renew some bushes on my VT series1. The service guy said the 'sway-bar link bushes' and the 'front caster bushes' need replacing. I looked in my Gregorys manual and can not find the 'front caster bushes'. Is there another name they go by?
    Thanks
  2. BlackVXGTS
    BlackVXGTS Well-Known Member
    Melbourne, SE
    VF2 GTS A6, VS Calais 383 A4, VS Clubsport 185 A4
    Sometimes they are called radius rod bushes or tension rod bushes.
  3. VTS5
    VTS5 TechJunkie
    Sth.East\Melb
    '97 VT Spack 5 Speed
    48166 is the caster bush :) .
  4. Blue Gemini
    Blue Gemini Guest
    Thanks for the replies so far.
    How do I know if the bushes are worn? I jacked up the car and took the left hand side wheel off to have a close look at the bushes. I took the bottom one off the sway bar and couldnt really see anything wrong with it. Mind you that I didnt know what to look for. So I have attached some pics.
    VT_Acclm, so that bush 48166 is not in the picture I took? Is it where the radius rod attaches to the front crossmember?
    http://i4.photobucket.com/albums/y135/quicksilverbmx/free_bush1.jpg
    Thanks again for the replies.
  5. shomesta
    shomesta New Member
    WH 5.7 A4
    i had mine replaced recently and the rubber bushes we actually torn and cracked and there was a rattling noise from the front of the car when i went over bumps. Its fine now.
    If yours is not making any rattling noises i dont know why you would change them. they look fine in the pic.
  6. ejukated
    ejukated New Member
    Vt-Acclm, where is that neat little diagram from?
  7. VTS5
    VTS5 TechJunkie
    Sth.East\Melb
    Scanned it from Nulon's catalog...
