FS: Custom T5 manual conversion VT-VY
jenkos_vl
37
i have a borg warner T5 manual conversion, customised to suit a VT-VY V6 commodore.
includes
-T5 manual gear box, with custom cross member
-new RPM heavduty organic clutch (less than 200kms use)
-8 bolt flywheel, machined less than 200kms ago
-clutch cable
-custom made tailshaft to suit vt-VY
-custom modified clutch pedal box, to suit vt-VY
-brand new throw out bearing
-brass spigot bush
pick up from SE melb, may arrange delivery for a fee.
$1500
(edit, sorry i ment 8 bolt flywheel)
Dan
CHEETR
VT feature car, WRX STI WAGON
why on earth would you put a cable manual in a car that runs a hydrolic manual
jenkos_vl
37
has this been in a car working? if so is there anything else that might be needed?
yes it has been running in my car, . but due to the balance in the L67 needing a heavier flywheel i couldnt eliminate a vibration. a heavier flywheel would of sloved the problem.
if you wanted to fit this to an L67 (supercharged V6) you would need a new flywheel
only thing not included is the kit is interior shifter boot.
cheeter, i used a cable clutch because the T5 belhousing uses a cable clutch, and i used the T5 because as blown v6 hatch has already eluded to, the getrag boxes are **** and expensive.
T5's are stronger and cheaper.
Dan
jenkos_vl
37
forgot to mention, also has the manual starter motor in the kit
CHEETR
ahh yer true ey
Shounak
The Kicking Horse
37
VX Executive S2 + XF Panel Van Project
Does this need an engine loom and memcal for the conversion to a VX? Also where abouts in SE suburbs are you located?
deanos70
are you selling the parts seperate or want them all gone in 1 go
