Troy5L
building a lemon
- Jun 2, 2005
- 485
- 7
- 18
- Age
- 36
- Location
- Mornington peninsula
- Gu patrol td42
ITEM: V1 T-Trim supercharger kit, its 99% complete. Just pulled it off my clubsport as im selling both..also comes with modified bannana manifold and crane cam lifters and springs..
CONDITION: Used, but supercharger has been rebuilt, everything inside is new. was rebuilt in october and hasnt even done 10,000km's
PRICE: $6,700ono, but not going much lower than that.
DELIVERY/PICK UP INFORMATIONickup from somerville(15 mins from frankston) or i can meet you somewhere
PAYMENT OPTIONS: COD, Direct Deposit
CONTACT DETAILS: pm or reply, if your real keen pm me and ill giv u me number
OTHER INFO:
Vortech V1 T-Trim supercharger with everything to bolt up to your 5lt V8..
This supercharger kit will fit 5lt 304's from VN-VT S1. pretty much every nut and bolt is included, also new belts for the alternator
and powersteerin pump, and brand new supercharger pulley.
Had this on my stock HSV VS Clubsport, running 9psi it made 237.2rwkw/318.1hp. The V1 has been rebuilt in october by
capa at a cost of $1300+..everything was replaced inside the supercharger and is brand new. I have never had a problem
with the supercharger at all while i had it and it sure felt strong with the v8..
The kit im selling includes:
*V1 T-Trim supercharger
*10psi pulley
*supercharger bracket, crank pulley and tensioner pulley
*Alternator, power steering and supercharger belts
*Intercooler(fits behind the bar, no need to cut anything)
*Intercooler piping, hoses, clamps and POD filter
*36lb injectors and Fuel regulator
*Oil feed line and oil drain line
*BOV
*hoses for BOV and a few other parts
*2BAR map sensor
*2 Memcal tunes, 1X tune by HPF at dandenong which made 237.2rwkw(with a slipping belt...1X tune by CVA performance in Hallam, was
in previous owners car which made 244rwkw from memory.Both memcals are Kalmakers
*Autometer Sport comp boost and fuel2air gauges
*Various bolts, clamps and hoses
*Modified 304 banana manifold-removed elbow, Trottle body facing forward like an LS1 manifold (was acid dipped and chemically cleaned) Never been used!
*Crane 286 cam, lifters and springs(used)-should be pushing 300rwkw with this installed with the supercharger
i have probably missed a few things but if i remember ill add them 2 the list..
Im asking $6700 for everything. It cost me a hell of alot more to get it running properly on my car.. I WILL NOT SEPERATE ANYTHING!!!!! also i will not be
posting this. We can meet up somewhere if you live a fair distance from the mornington peninsula or pickup from Somerville, which is only 15 mins past frankston.
PICTURES:
OTHER INFO:
*10psi pulley
*BOV
*2BAR map sensor
PICTURES:
