Fuel gauge
katiereb
Tamworth
Vs commordore
Hi. I recently got a new fuel pump put in and now my fuel gauge isn't working properly only goes to the next line and that's it. I have a vs commordore wagon 97
Any help will be good.
woteva
NEED 4 SPEED
Adelaide S.A.
Need to remove the fuel pump/sender unit from the tank and rectify.
Most likely the fuel level float arm is caught or bent.
If you had it done by a shop, take it back and see if they will fix for free. With a hoist, it will only take a few minutes to remove and refit if the tank is nearly empty.
BlackVXGTS
Melbourne, SE
+1 for problem with sender unit. They are very fiddly to reinstall.
vs-lover
VS S2 Calais, VS S2 Exec Wagon, VS S2 Acclaim
They are if it's a Live Axle, but a tank removal job if it's in an IRS fitted vehicle.
losh1971
North Tas
VE Series I SS Ute
Yeah I snapped the float getting mine out or back in, can't remember which. I used a cable tie to fix it. It was fine after that.
BlackVXGTS
Melbourne, SE
Is that comment specifically related to wagons? I've replaced the fuel pump on my VS Calais V8 and VS Clubsport sedans in the driveway without having to remove the tank.
vs-lover
Oh Wow !, I've always been of the understanding that the space given between the body mounted Diff and the tank sender is not enough to maneuver it out, obviously I'm wrong.
BTW wagons never had IRS fitted until VT.
