fuel pump failures after motor out
bsb84
sunshine coast
5L vs ute
in december i drove my ute into the shed, pulled the motor n box out and put a 5 speed and the motor back in, after all the codes, new ignition module, coil and dizzy, wouldnt start and wouldnt clear error code 46. got a mobile mechanic to have a look and after awhile he threw the pressure gauge on the fuel line and found no pressure, replaced the pump and she was good. last saturday, i pulled the motor out to change the clutch, put it back in, wouldnt start, threw up code for the hall effect sensor again so went and got another new dizzy, put it in, nothing, cleared codes, checked em again and 46. been over the wiring, seems all g, decided to pull the fuel line and no fuel, so guessing pump again, if it is just the pump, does anyone have any idea why pulling the motor out would stuff the fuel pump
jeepster
WA
VSII Ute
Fuel pumps don't seem to like stale petrol. Although 4 months seems a bit short to stuff it up.
Bowen
Alstonville
2002 VX S manual 3.8L SP
Make sure you use oem or walbro pump not a cheap ebay thing
Deuce
Super Stock
'94 VR SS V8
My vr was off the road for 3 months and pump was fine.
Although it couldn't keep up with the power of the new engine so got replaced anyway.
Did you replace with new or second hand.
