Fuel pump
Triox
64
The fuel pump does not run unless I bridge the ALDL connectors fuel pump test terminal G and H.
The fuses relay and wiring seem ok.
The engine cuts out when bridge is removed.
Any ideas?
vpdood
37
west aussie
92 vp berlina
check oil pressure switch is all fine and dandy
Triox
64
Yep all seems fine, I did notice today that if I jiggle the wires around the relays in the engine bay it will work, I just have to find out what wire is causing the problem.
When the mysterious wire is alright everything works fine,
the car even starts without fuel pump via the oil pressure switch as it should,
but when the wire is in it,s "OFF" mode the only way to start is via the ALDL
plug.
