Fuel Smell inside car
Discussion in 'VT - VX Holden Commodore (1997 - 2002)' started by Secki, Feb 17, 2006.
  1. Secki
    Secki New Member
    Southern Highlands
    VH Wagon SLX 253
    ive been having this problem on and off for a while now, sometimes after say an hour on the freeway, then into start stop drving i get the smell of petrol in my cabin. It also happened today, after driving around for about an hour in the city/cronulla.
    You cannot smell it from the outside of the car, or under the bonnet, only inside the cabin.
    Any ideas people?
    PS its a VT SS 5.0l
  2. ScottB_33
    ScottB_33 Go Hard or Go Home
    Nowra
    VTII Berlina Supercharged
    Sorry Secki but there is no way that fuel can enter the cabin without coming from either the engine bay or under the vehicle. My guess is the fuel line is leaking at the joint just near the firewall and the smell is coming from the engine bay into the cabin via a hole from a grommet that may be missing or damaged in some way. The reason you may not be finding it so easy is that fuel evaporates incredibly quickly in a hot engine bay. Hope this helps but I would really need to see the car to diagnose correctly.
  3. VL-187
    VL-187 ZZZZZZZZTUUUTUUUTUUU
    Bagged VS calais II
    could be ur injectors, have a look 2 c if u can c any leaks...
    i had the same problem with my vl.....
  4. Secki
    Secki New Member
    Southern Highlands
    VH Wagon SLX 253
    injectors are fine, chad them checked out, its wierd how only after freeway driving or start stop driving in the heat it happens, im thinking yeha maybe somewhere in the firewall
  5. phild257
    phild257 Phil
    VT Calais 5.0L
    Most probably your vapour (carbon) canister. This canister filters fuel vapour from the fuel tank through carbon. If the carbon becoms clogged or the vent hose bocomes blocked, you can get petrol smells inside the cabin, esp on hot days or after comming to a stop.
