Fuel Tank,Fuel Pump Assembly and Swirl Pot.
markovr
62
northside brisbane
youtu.be
07vessv 94vr .04vz wgn,93vp wgn,82 vhV6 wgn 88 vn
My car let me down yesterday by stalling at the lights and not starting again and the tank was a little under 1/4.... pushed the car until I got sick of it and the ground was more level got it going for a short time again and drove it to the servo but it stopped again but this time 10 feet from the fuel pump at the servo....it started after a couple of attempts for long enough to get it to the pump so I filled it up and now its runs fine ...Im assuming its a broken return line and I want to fix it soon. I do everything on my car myself and have fixed fuel line leaks at the tank before using solder and normal soldering iron....I was thinking of taking tank out and emptying out the fuel and filling up with water and cutting open tank and fixing the hose myself and soldering it back up...anyone else done it this way?
Brett_jjj
Tamworth NSW
vs commodore
Mate,I dont think its really worth the trouble.Id just get a second hand tank from the wreckers if the return line is broken off from the swirl pot in your tank.There was one guy on here who cut his fuel tank open to fix the return line.I dont think he had much success with it.Im pretty sure he just ended up getting a second hand tank to fit instead.
markovr
62
northside brisbane
youtu.be
Cant believe this but my 12 yr old son has hands small enough to fit through the sender hole..he just undid the clamp and took the hose off...and replaced and did up .....took 2 mins...no welding no worries
markovr
62
northside brisbane
youtu.be
Just found out that holden service the return hose that goes between the swirl pot and sender unit pipe and it comes complete with the connection to the sender unit pipe on it and for 15 dollars .......part number 92047898 its pre bent and the actual connection has ears that release from the side and you can do it with your fingers so you dont need any tools...much better than the old one....and the part is made in australia not turkey like the ripco version
hako
Donating Member
80
Toowoomba SE QLD
VS11 BT1 V6
There is always a simple answer to a complex problem eh! That is really "thinking outside the square" yet totally logical. Good one:beer chug:
commatador
sa
VR Wagon
Hay I just found how to do it!!..
To replace the hose between the sender and the swirl pot inside your tank you don’t need to undo the hose clamp (you can see when you look inside your tank at the end of the hose), nor do you need to have a 12 year old son.
Simply get your long nose pliers grabe the hose and yank it out of the tank. Both the hose and a plastic conector that clips into the swirl pot come out, you can then undo the hose clamp and replace the hose back on to the plastice conector . Then guide the new hose with the plastic conector back into tanks swirl pot hole. You may need to rotate the hose once the plactic conector is in the swirl pot hole to get it to "click in"..
That's it!!
Good pictures.. Thanks
outseeker
outer.reaches.dyndns.org
S2 VN Calais V6
Yes. Extremely handy!! :D
Heres some pics of the inside of the fuel tank with the pump assembly fitted.
My swirl pot (not the one in the pic) was loose and floating around on the bottom of the tank so I cut open another old tank to see how it is meant to go.Ive never had fuel pickup problems either.I thought these might be handy for anyone changing their fuel pump as they can get an idea of how the pump sits in the tank and how the return hose is connected inside the tank.
You are a total legend! Those pics are (as you had hoped) incredibly useful! Thanks so very much mate :D
VR38
VB SL/E
No need to cut the tank open if you are just replacing the return hose, with a pair of long nose pliers just grab and pull the ventry (the bit the hose is connected to) and pull it out, replace the hose, then guide the ventry back into place with the new hose connected and push and click it back into place.
Pollushon
Boost gives me a bar....
VY SS
Keep meaning to say thank you Brett on this one. The guide by Jxw was very good but this was just the icing on the cake when I whacked in my Walbro. Seeing how it all lives together made it painless and about one hours work including the mods to make the Walbro fit.
Very clever thought mate.
Nzguzzi
New Zealand
1989 VN Executive Wagon
Cheers for this guide on how to.
My VN was running out of gas on a little less than 1/4 of a tank after the mechanic changed over the fuel sender unit.
Now that we know what it is, we can solve the mystery.
