Fuel tank return repair VN V6 manual wagon
WhiteWhale
Australia
VN S1 wagon M5
Some numpty has attempted to repair the fuel return line barb into the tank and it’s not working out.
The barb seems to slide in and out a couple of mms.
This combined with all the vapour hoses being either cracked or totally MIA might explain the crap mileage I get from the clunker. I do about 700km a week, all 80-100kmh stuff.
Is there anything out there that’ll seal it up until I can find another tank for it?
I’m going through forum posts to figure out how the 3 vapour hoses hook up on the 4 barbed joiner. I guess one leg if it goes to the barn on top of the fuel filler pipe.
WhiteWhale
Australia
VN S1 wagon M5
This is a pic of it
Hole Denn
SA
HoleDens
yeah petrol will sieve through and leak from using that putty ****, eventually going hard and cracking.
Best fix is solder, a radiator repair place can oxy weld some solder on for you like the do with the copper tanks.
Hole Denn
SA
HoleDens
don"t forget the return line to the canister/engine bay
WhiteWhale
Australia
VN S1 wagon M5
Cheers, that’s also cracked and broken too, from the hard pipe to the filler pipe.
I’ve found a pic from a vg that looks the same as the wagon.
Just gotta buy a couple metres of hose and hook it all up.
Think I’ll leave the fuel return line alone. It’s not leaking that I can tell so I’ll leave that sort out later.
Gotta get the O2 sensor out and replaced which looks like a mongrel of a job for access.
WhiteWhale
Australia
VN S1 wagon M5
I’m guessing that’s a tank out job?
Fu Manchu
WA.
It’s repairable. I had the tank in my VP ute done. Pretty sure it was the local radiator shop that did it. Resoldered the barbs.
