3D Mark 06 Results
3D Mark: 10533
SM 2.0: 4791
SM 3.0 5502
CPU Score: 2078
CPU - Z Dump:
CPU-Z version 1.51
Processors Map
Number of processors 1
Number of threads 2
Processor 0
-- Core 0
-- Thread 0
-- Core 1
-- Thread 0
Processors Information
Processor 1 (ID = 0)
Number of cores 2 (max 2)
Number of threads 2 (max 2)
Name Intel Core 2 Duo E6600
Codename Conroe
Specification Intel(R) Core(TM)2 CPU 6600 @ 2.40GHz
Package Socket 775 LGA (platform ID = 0h)
CPUID 6.F.6
Extended CPUID 6.F
Core Stepping B2
Technology 65 nm
Core Speed 1598.4 MHz (6.0 x 266.4 MHz)
Rated Bus speed 1065.6 MHz
Stock frequency 2400 MHz
Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, EM64T
L1 Data cache 2 x 32 KBytes, 8-way set associative, 64-byte line size
L1 Instruction cache 2 x 32 KBytes, 8-way set associative, 64-byte line size
L2 cache 4096 KBytes, 16-way set associative, 64-byte line size
FID/VID Control yes
FID range 6.0x - 9.0x
max VID 1.313 V
Features XD, VT
Thread dumps
CPU Thread 0
APIC ID 0
Topology Processor ID 0, Core ID 0, Thread ID 0
Type 01008001h
Max CPUID level 0000000Ah
Max CPUID ext. level 80000008h
Function eax ebx ecx edx
0x00000000 0x0000000A 0x756E6547 0x6C65746E 0x49656E69
0x00000001 0x000006F6 0x00020800 0x0000E3BD 0xBFEBFBFF
0x00000002 0x05B0B101 0x005657F0 0x00000000 0x2CB43049
0x00000003 0x00000000 0x00000000 0x00000000 0x00000000
0x00000004 0x04000121 0x01C0003F 0x0000003F 0x00000001
0x00000004 0x04000122 0x01C0003F 0x0000003F 0x00000001
0x00000004 0x04004143 0x03C0003F 0x00000FFF 0x00000001
0x00000005 0x00000040 0x00000040 0x00000003 0x00000020
0x00000006 0x00000001 0x00000002 0x00000001 0x00000000
0x00000007 0x00000000 0x00000000 0x00000000 0x00000000
0x00000008 0x00000400 0x00000000 0x00000000 0x00000000
0x00000009 0x00000000 0x00000000 0x00000000 0x00000000
0x0000000A 0x07280202 0x00000000 0x00000000 0x00000000
0x80000000 0x80000008 0x00000000 0x00000000 0x00000000
0x80000001 0x00000000 0x00000000 0x00000001 0x20100000
0x80000002 0x65746E49 0x2952286C 0x726F4320 0x4D542865
0x80000003 0x43203229 0x20205550 0x20202020 0x20202020
0x80000004 0x30303636 0x20402020 0x30342E32 0x007A4847
0x80000005 0x00000000 0x00000000 0x00000000 0x00000000
0x80000006 0x00000000 0x00000000 0x10008040 0x00000000
0x80000007 0x00000000 0x00000000 0x00000000 0x00000000
0x80000008 0x00003024 0x00000000 0x00000000 0x00000000
Cache descriptor Level 1 D 32 KB 1 thread(s)
Cache descriptor Level 1 I 32 KB 1 thread(s)
Cache descriptor Level 2 U 4 MB 2 thread(s)
MSR 0x0000001B edx = 0x00000000 eax = 0xFEE00900
MSR 0x000000E8 edx = 0x000001C1 eax = 0xBB6DF9D4
MSR 0x00000017 edx = 0x00000000 eax = 0x88048927
MSR 0x000000CD edx = 0x00000000 eax = 0x00000800
MSR 0x0000003F edx = 0x00000000 eax = 0x000000EA
MSR 0x000000CE edx = 0x001B0927 eax = 0x7F7F071B
MSR 0x000001A0 edx = 0x00000040 eax = 0x62972489
MSR 0x000000EE edx = 0xA8000000 eax = 0xC17D4300
MSR 0x0000011E edx = 0x00000000 eax = 0xBE702109
MSR 0x0000019C edx = 0x00000000 eax = 0x88140000
MSR 0x00000198 edx = 0x09270927 eax = 0x06320627
MSR 0x00000199 edx = 0x00000000 eax = 0x00000927
CPU Thread 1
APIC ID 1
Topology Processor ID 0, Core ID 1, Thread ID 0
Type 01008001h
0x00000001 0x000006F6 0x01020800 0x0000E3BD 0xBFEBFBFF
MSR 0x0000001B edx = 0x00000000 eax = 0xFEE00800
MSR 0x000000E8 edx = 0x00000114 eax = 0x56C0CE2F
MSR 0x0000019C edx = 0x00000000 eax = 0x88160000
MSR 0x00000198 edx = 0x09270927 eax = 0x06000927
Chipset
Northbridge Intel P965/G965 rev. C2
Southbridge Intel 82801HB/HR (ICH8/R) rev. B0
Graphic Interface PCI-Express
PCI-E Link Width x16
PCI-E Max Link Width x16
Memory Type DDR2
Memory Size 4096 MBytes
Memory SPD
DIMM #1
General
Memory type DDR2
Module format Regular UDIMM
Manufacturer (ID) Kingston (7F98000000000000)
Size 2048 MBytes
Max bandwidth PC2-6400 (400 MHz)
Part number 2G-UDIMM
Serial number 3538362F
Manufacturing date Week 32/Year 08
Attributes
Number of banks 2
Data width 64 bits
Correction None
Nominal Voltage 1.80 Volts
EPP no
XMP no
Timings table
Frequency (MHz) 200 266 400
CAS# 3.0 4.0 5.0
RAS# to CAS# delay 3 4 5
RAS# Precharge 3 4 5
TRAS 9 12 18
TRC 12 16 23
DIMM #2
General
Memory type DDR2
Size 2048 MBytes
Serial number 34385B2F
Attributes
Number of banks 2
Data width 64 bits
Correction None
EPP no
XMP no
Timings table
CAS# 3.0 4.0 5.0
TRAS 9 12 18
TRC 12 16 23
Monitoring
Mainboard Model DG965SS (0x1D5 - 0x5794B3)
LPCIO
Vendor NS
Model PC8374L
Vendor ID 0xFF02
Chip ID 0xF1
Revision ID 0x4
Config Mode I/O address 0x2E
Hardware monitor
Intel HECI hardware monitor
Voltage sensor 0 12.14 Volts [0x2F68] (+12V)
Voltage sensor 1 5.10 Volts [0x13ED] (+5V)
Voltage sensor 2 3.28 Volts [0xCCF] (+3.3V)
Voltage sensor 3 1.25 Volts [0x4E5] (AUX)
Voltage sensor 4 1.15 Volts [0x481] (CPU VCORE)
Temperature sensor 0 59°C (138°F) [0x3B] (CPU)
Temperature sensor 1 58°C (136°F) [0x3A] (Mainboard)
Temperature sensor 3 46°C (114°F) [0x2E] (ICH)
Temperature sensor 4 75°C (166°F) [0x4B] (MCH)
Temperature sensor 5 57°C (134°F) [0x39] (TMPIN5)
Fan sensor 0 1096 RPM [0x448] (CPU)
Fan sensor 2 1452 RPM [0x5AC] (Rear)
Dump hardware monitor
Register space class = 0x15, base address = 0xFFFFFFFFFFFFFFFF
Hardware monitor
Intel Core 2 Duo E6600 hardware monitor
Temperature sensor 0 65°C (148°F) [0x14] (Core #0)
Temperature sensor 1 63°C (145°F) [0x16] (Core #1)
Hardware monitor
GeForce 9800 GTX+ hardware monitor
Temperature sensor 0 47°C (116°F) [0x2F] (GPU Core)
PCI Device List
Host Bridge
bus 0 (0x00), device 0 (0x00), function 0 (0x00)
Common header
Vendor ID 0x8086
Model ID 0x29A0
Revision ID 0x02
PI 0x00
SubClass 0x00
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Subvendor ID 0x8086
Subsystem ID 0x514D
Int. Line 0x00
Int. Pin 0x00
Capabilities
Vendor Dependant Capability
Offset E0h
PCI to PCI Bridge
bus 0 (0x00), device 1 (0x01), function 0 (0x00)
Common header
Vendor ID 0x8086
Model ID 0x29A1
Revision ID 0x02
PI 0x00
SubClass 0x04
BaseClass 0x06
Cache Line 0x10
Latency 0x00
Header 0x01
PCI header
Primary bus 0x00
Secondary bus 0x01
Int. Line 0x10
Int. Pin 0x01
Capabilities
Subsystem Vendor Capability
Offset 88h
Subsystem ID 0x514D
Sub. Vendor ID 0x8086
Power Management Capability
Offset 80h
Version 1.2
Message Signalled Interrupts Capability
Offset 90h
PCI Express Capability
Offset A0h
Device type Root Port of PCI-E Root Complex
Port 2
Version 1.0
Physical slot #0
Presence detect yes
Link width 16x (max 16x)
Extended capabilities
Virtual Channel
Offset 100h
Root Complex Link Declaration
Offset 140h
Link Entries # 1
Port Number 2
Communication Device
bus 0 (0x00), device 3 (0x03), function 0 (0x00)
Common header
Vendor ID 0x8086
Model ID 0x29A4
Revision ID 0x02
PI 0x00
SubClass 0x80
BaseClass 0x07
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Address 0 (memory) 0xE3225900
Subvendor ID 0x8086
Subsystem ID 0x514D
Int. Line 0x10
Int. Pin 0x01
Capabilities
Offset 50h
Version 1.2
Offset 8Ch
Ethernet Controller
bus 0 (0x00), device 25 (0x19), function 0 (0x00)
Common header
Vendor ID 0x8086
Model ID 0x104B
Revision ID 0x02
PI 0x00
SubClass 0x00
BaseClass 0x02
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Address 0 (memory) 0xE3200000
Address 1 (memory) 0xE3224000
Subvendor ID 0x8086
Subsystem ID 0x0001
Int. Line 0x00
Int. Pin 0x01
Capabilities
Offset C8h
Version 1.1
Offset D0h
USB Controller (UHCI)
bus 0 (0x00), device 26 (0x1A), function 0 (0x00)
Common header
Vendor ID 0x8086
Model ID 0x2834
Revision ID 0x02
PI 0x00
SubClass 0x03
BaseClass 0x0C
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Address 4 (port) 0x000030A0
Subvendor ID 0x8086
Subsystem ID 0x514D
Int. Line 0x10
Int. Pin 0x01
bus 0 (0x00), device 26 (0x1A), function 1 (0x01)
Common header
Vendor ID 0x8086
Model ID 0x2835
Revision ID 0x02
PI 0x00
SubClass 0x03
BaseClass 0x0C
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Address 4 (port) 0x00003080
Subvendor ID 0x8086
Subsystem ID 0x514D
Int. Line 0x15
Int. Pin 0x02
USB 2.0 Controller (EHCI)
bus 0 (0x00), device 26 (0x1A), function 7 (0x07)
Common header
Vendor ID 0x8086
Model ID 0x283A
Revision ID 0x02
PI 0x20
SubClass 0x03
BaseClass 0x0C
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Address 0 (memory) 0xE3225400
Subvendor ID 0x8086
Subsystem ID 0x514D
Int. Line 0x12
Int. Pin 0x03
Capabilities
Offset 50h
Version 1.1
Debug Port Capability
Offset 58h
Multimedia device
bus 0 (0x00), device 27 (0x1B), function 0 (0x00)
Common header
Vendor ID 0x8086
Model ID 0x284B
Revision ID 0x02
PI 0x00
SubClass 0x03
BaseClass 0x04
Cache Line 0x10
Latency 0x00
Header 0x00
PCI header
Address 0 (memory) 0xE3220000
Subvendor ID 0x8086
Subsystem ID 0x2114
Int. Line 0x16
Int. Pin 0x01
Capabilities
Offset 50h
Version 1.1
Offset 60h
Offset 70h
Device type Root Complex Integrated Endpoint Device
Port 0
Version 1.0
Link width 0x (max 0x)
Virtual Channel
Offset 100h
Offset 130h
Link Entries # 1
Port Number 15
PCI to PCI Bridge
bus 0 (0x00), device 28 (0x1C), function 0 (0x00)
Common header
Vendor ID 0x8086
Model ID 0x283F
Revision ID 0x02
PI 0x00
SubClass 0x04
BaseClass 0x06
Cache Line 0x10
Latency 0x00
Header 0x81
PCI header
Primary bus 0x00
Secondary bus 0x02
Int. Line 0x11
Int. Pin 0x01
Capabilities
Offset 40h
Port 1
Version 1.0
Physical slot #0
Presence detect no
Link width 0x (max 1x)
Offset 80h
Offset 90h
Subsystem ID 0x283F
Offset A0h
Version 1.1
Virtual Channel
Offset 100h
Offset 180h
Link Entries # 1
Port Number 1
PCI to PCI Bridge
bus 0 (0x00), device 28 (0x1C), function 1 (0x01)
Common header
Vendor ID 0x8086
Model ID 0x2841
Revision ID 0x02
PI 0x00
SubClass 0x04
BaseClass 0x06
Cache Line 0x10
Latency 0x00
Header 0x81
PCI header
Primary bus 0x00
Secondary bus 0x03
Int. Line 0x10
Int. Pin 0x02
Capabilities
Offset 40h
Port 2
Version 1.0
Physical slot #0
Presence detect yes
Link width 1x (max 1x)
Offset 80h
Offset 90h
Subsystem ID 0x2841
Offset A0h
Version 1.1
Virtual Channel
Offset 100h
Offset 180h
Link Entries # 1
Port Number 2
PCI to PCI Bridge
bus 0 (0x00), device 28 (0x1C), function 2 (0x02)
Common header
Vendor ID 0x8086
Model ID 0x2843
Revision ID 0x02
PI 0x00
SubClass 0x04
BaseClass 0x06
Cache Line 0x10
Latency 0x00
Header 0x81
PCI header
Primary bus 0x00
Secondary bus 0x04
Int. Line 0x12
Int. Pin 0x03
Capabilities
Offset 40h
Port 3
Version 1.0
Physical slot #0
Presence detect no
Offset 80h
Offset 90h
Subsystem ID 0x2843
Offset A0h
Version 1.1
Virtual Channel
Offset 100h
Offset 180h
Link Entries # 1
Port Number 3
PCI to PCI Bridge
bus 0 (0x00), device 28 (0x1C), function 3 (0x03)
Common header
Vendor ID 0x8086
Model ID 0x2845
Revision ID 0x02
PI 0x00
SubClass 0x04
BaseClass 0x06
Cache Line 0x10
Latency 0x00
Header 0x81
PCI header
Primary bus 0x00
Secondary bus 0x05
Int. Line 0x13
Int. Pin 0x04
Capabilities
Offset 40h
Port 4
Version 1.0
Physical slot #0
Presence detect no
Offset 80h
Offset 90h
Subsystem ID 0x2845
Offset A0h
Version 1.1
Virtual Channel
Offset 100h
Offset 180h
Link Entries # 1
Port Number 4
PCI to PCI Bridge
bus 0 (0x00), device 28 (0x1C), function 4 (0x04)
Common header
Vendor ID 0x8086
Model ID 0x2847
Revision ID 0x02
PI 0x00
SubClass 0x04
BaseClass 0x06
Cache Line 0x10
Latency 0x00
Header 0x81
PCI header
Primary bus 0x00
Secondary bus 0x06
Int. Line 0x11
Int. Pin 0x01
Capabilities
Offset 40h
Port 5
Version 1.0
Physical slot #0
Presence detect no
Offset 80h
Offset 90h
Subsystem ID 0x2847
Offset A0h
Version 1.1
Virtual Channel
Offset 100h
Offset 180h
Link Entries # 1
Port Number 5
bus 0 (0x00), device 29 (0x1D), function 0 (0x00)
Common header
Vendor ID 0x8086
Model ID 0x2830
Revision ID 0x02
PI 0x00
SubClass 0x03
BaseClass 0x0C
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Address 4 (port) 0x00003060
Subvendor ID 0x8086
Subsystem ID 0x514D
Int. Line 0x17
Int. Pin 0x01
bus 0 (0x00), device 29 (0x1D), function 1 (0x01)
Common header
Vendor ID 0x8086
Model ID 0x2831
Revision ID 0x02
PI 0x00
SubClass 0x03
BaseClass 0x0C
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Address 4 (port) 0x00003040
Subvendor ID 0x8086
Subsystem ID 0x514D
Int. Line 0x13
Int. Pin 0x02
bus 0 (0x00), device 29 (0x1D), function 2 (0x02)
Common header
Vendor ID 0x8086
Model ID 0x2832
Revision ID 0x02
PI 0x00
SubClass 0x03
BaseClass 0x0C
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Address 4 (port) 0x00003020
Subvendor ID 0x8086
Subsystem ID 0x514D
Int. Line 0x12
Int. Pin 0x03
bus 0 (0x00), device 29 (0x1D), function 7 (0x07)
Common header
Vendor ID 0x8086
Model ID 0x2836
Revision ID 0x02
PI 0x20
SubClass 0x03
BaseClass 0x0C
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Address 0 (memory) 0xE3225000
Subvendor ID 0x8086
Subsystem ID 0x514D
Int. Line 0x17
Int. Pin 0x01
Capabilities
Offset 50h
Version 1.1
Offset 58h
PCI to PCI Bridge
bus 0 (0x00), device 30 (0x1E), function 0 (0x00)
Common header
Vendor ID 0x8086
Model ID 0x244E
Revision ID 0xF2
PI 0x01
SubClass 0x04
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x01
PCI header
Primary bus 0x00
Secondary bus 0x07
Int. Line 0xFF
Int. Pin 0x00
Capabilities
Offset 50h
Subsystem ID 0x514D
PCI to ISA Bridge
bus 0 (0x00), device 31 (0x1F), function 0 (0x00)
Common header
Vendor ID 0x8086
Model ID 0x2810
Revision ID 0x02
PI 0x00
SubClass 0x01
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x8086
Subsystem ID 0x514D
Int. Line 0x00
Int. Pin 0x00
Capabilities
Offset E0h
IDE Controller
bus 0 (0x00), device 31 (0x1F), function 2 (0x02)
Common header
Vendor ID 0x8086
Model ID 0x2820
Revision ID 0x02
PI 0x8F
SubClass 0x01
BaseClass 0x01
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Address 0 (port) 0x00003138
Address 1 (port) 0x0000314C
Address 2 (port) 0x00003130
Address 3 (port) 0x00003148
Address 4 (port) 0x00003110
Address 5 (port) 0x00003100
Subvendor ID 0x8086
Subsystem ID 0x514D
Int. Line 0x13
Int. Pin 0x01
Capabilities
Offset 70h
Version 1.2
SMBus Controller
bus 0 (0x00), device 31 (0x1F), function 3 (0x03)
Common header
Vendor ID 0x8086
Model ID 0x283E
Revision ID 0x02
PI 0x00
SubClass 0x05
BaseClass 0x0C
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Address 0 (memory) 0xE3225800
Address 4 (port) 0x00003000
Subvendor ID 0x8086
Subsystem ID 0x514D
Int. Line 0x0A
Int. Pin 0x02
IDE Controller
bus 0 (0x00), device 31 (0x1F), function 5 (0x05)
Common header
Vendor ID 0x8086
Model ID 0x2825
Revision ID 0x02
PI 0x85
SubClass 0x01
BaseClass 0x01
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Address 0 (port) 0x00003128
Address 1 (port) 0x00003144
Address 2 (port) 0x00003120
Address 3 (port) 0x00003140
Address 4 (port) 0x000030F0
Address 5 (port) 0x000030E0
Subvendor ID 0x8086
Subsystem ID 0x514D
Int. Line 0x13
Int. Pin 0x01
Capabilities
Offset 70h
Version 1.2
VGA Controller
bus 1 (0x01), device 0 (0x00), function 0 (0x00)
Common header
Vendor ID 0x10DE
Model ID 0x0613
Revision ID 0xA2
PI 0x00
SubClass 0x00
BaseClass 0x03
Cache Line 0x10
Latency 0x00
Header 0x00
PCI header
Address 0 (memory) 0xE2000000
Address 1 (memory) 0xD0000000
Address 3 (memory) 0xE0000000
Address 5 (port) 0x00002000
Subvendor ID 0x107D
Subsystem ID 0x2AB8
Int. Line 0x10
Int. Pin 0x01
Capabilities
Offset 60h
Version 1.2
Offset 68h
Offset 78h
Device type PCI-E Endpoint Device
Port 0
Version 1.0
Virtual Channel
Offset 100h
Power Budgeting Capability
Offset 128h
Vendor Specific
Offset 600h
Vendor ID 1
Size 36
IDE Controller
bus 3 (0x03), device 0 (0x00), function 0 (0x00)
Common header
Vendor ID 0x11AB
Model ID 0x6101
Revision ID 0xB1
PI 0x8F
SubClass 0x01
BaseClass 0x01
Cache Line 0x10
Latency 0x00
Header 0x00
PCI header
Address 0 (port) 0x00001018
Address 1 (port) 0x00001024
Address 2 (port) 0x00001010
Address 3 (port) 0x00001020
Address 4 (port) 0x00001000
Address 5 (memory) 0xE3100000
Subvendor ID 0x11AB
Subsystem ID 0x6101
Int. Line 0x11
Int. Pin 0x01
Capabilities
Offset 48h
Version 1.1
Offset 50h
Offset E0h
Device type Legacy PCI-E Endpoint Device
Port 0
Version 1.0
Advanced Error Reporting Capability
Offset 100h
OHCI FireWire Controller
bus 7 (0x07), device 3 (0x03), function 0 (0x00)
Common header
Vendor ID 0x104C
Model ID 0x8023
Revision ID 0x00
PI 0x10
SubClass 0x00
BaseClass 0x0C
Cache Line 0x10
Latency 0x20
Header 0x00
PCI header
Address 0 (memory) 0xE3004000
Address 1 (memory) 0xE3000000
Subvendor ID 0x8086
Subsystem ID 0x514D
Int. Line 0x13
Int. Pin 0x01
Capabilities
Offset 44h
Version 1.1
DMI
DMI Processor
manufacturer Intel(R) Corporation
model Intel(R) Core(TM)2 CPU 6600 @ 2.40GHz
clock speed 2400.0 MHz
FSB speed 266.0 MHz
multiplier 9.0x
DMI BIOS
vendor Intel Corp.
version MQ96510J.86A.1669.2007.0406.0107
date 04/06/2007
DMI System Information
manufacturer unknown
product unknown
version unknown
serial unknown
UUID 3637DDC2-E87C11DB-911D00E0-18BFD7DC
DMI Baseboard
vendor Intel Corporation
model DG965SS
revision AAD41678-306
serial BQSS715001AJ
DMI System Enclosure
chassis type Desktop
chassis serial unknown
DMI Port Connector
designation PRIMARY (internal)
connector On Board IDE
DMI Port Connector
designation SECONDARY (internal)
DMI Port Connector
designation ATX_PWR (internal)
DMI Extension Slot
designation PCIE X16 SLOT
type A5
populated yes
DMI Extension Slot
designation PCIE X1 SLOT 1
type A5
populated no
DMI Extension Slot
designation PCI SLOT 1
type PCI
width 32 bits
populated no
DMI Extension Slot
designation PCI SLOT 2
type PCI
width 32 bits
populated no
DMI Physical Memory Array
location Motherboard
usage System Memory
correction None
max capacity 8192 MBytes
max# of devices 4
DMI Memory Device
designation J6H1
format DIMM
type unknown
total width 64 bits
data width 64 bits
size 2048 MBytes
DMI Memory Device
designation J6H2
format DIMM
type unknown
DMI Memory Device
designation J6J1
format DIMM
type unknown
DMI Memory Device
designation J6J2
format DIMM
type unknown
total width 64 bits
data width 64 bits
size 2048 MBytes
Display API(s)
NVIDIA direct I/O API
NVAPI display API
Display Adapter(s)
Device number 0
Name GeForce 9800 GTX+
Vendor ID 0x10DE (0x107D)
Model ID 0x613 (0x2AB8)
Revision ID 0xA2
Perf Level Default
GPU core clock 300.0 MHz
GPU shaders clock 600.0 MHz
GPU memory clock 100.0 MHz
Perf Level 3D Applications
GPU core clock 738.0 MHz
GPU shaders clock 1836.0 MHz
GPU memory clock 1100.0 MHz
GPU temperature 47 C
Display I2C
Software
Windows Version Microsoft Windows Vista (6.0) Home Premium Edition Service Pack 1 (Build 6001)
DirectX Version 10.0
