edals
over time every cars coolant turns brown and ends up with glunky deposits, which is why you have to or should flush it every so often. mines slightly brown (still green) my mates cars are the same and there all serviced by reputable mechanics regularly.
unless urs is different, which it doesnt sound, your car should be FINE
You Have to remember Theres a difference between oil and just normal Rust in the coolant. Depending on the age and how many kms is on it.
If you see oil in it theres a gasket leak, can easily tell when you see oil around your rad cap and it floating on the top of the coolant, should never be oil in the coolant, rust sure cant escape that
