Handbrake Adjustment VZ Commodore
Discussion in 'VZ Holden Commodore (2004 - 2006)' started by impulsive, Dec 13, 2010.
  1. impulsive
    impulsive Alloytec Racing
    Brisbane, QLD
    VZ Alloytec
    Any one point me in the right direction on how to adjust the handbrake, it has got to the point where it no longer engages and requires attention. Is it adjusted near the handbrake or down near the shoes?
  2. Calaber
    Lower Hunter Region NSW
    CG Captiva 5 Series 2
    Hi Impulsive
    I'm sure your VZ would be similar to my VY. I removed a rear wheel and disc recently to adjust the handbrake at the rear drum, only to find that the brake shoes are one piece with no adjustment. That meant that I adjusted the handbrake at the handbrake handle. Push the driver's seat right back and pull the bottom of the rubber cover back from the handbrake mechanism down beside the console. You will see a screw and nut adjustment there.
    Jack one rear wheel clear of the ground and make sure you can safely release the handbrake without the car rolling, then let it off and ensure the handle is full down. Adjust the nut down the thread until it only takes about three or four clicks on the handle ratchet before the rear wheel can't be spun by hand.
    Don't over-adjust the nut - you only want the tiniest amount of "drag" on the wheel when the brake is fully released. You might not be able to feel the drag but should be able to just hear the shoes barely rubbing on the drum as the wheel rotates.
  3. impulsive
    Brisbane, QLD
    VZ Alloytec
    so turns out i did what you mentioned.. handbrake 4 clicks etc, feels tighter... still doesnt hold the car going backwards...
  4. Calaber
    Ok, you will need to check the condition of the brake linings and drums and see if there is excessive dust build up, which can reduce the brake efficiency. Remove both rear wheels, calipers and caliper brackets, then ease each disc off the hub.
    Thoroughly de-dust handbrake shoes and mechanisms and clean out inside the drums. Are the shoes and the inside of the drums in good condition? If the car has been driven with the handbrake left on sometime during its life, the drums can be grooved and the shoes worn out as they are only pretty small. Also check to see that the brake actuating arm and shoes are free to move when the brake is pulled on.
    Once you have cleaned and checked everything, and replaced anything that was worn out, re-assemble and check for cable stretch or tightness in the conduit between the rear brakes and the front cable. I'm not sure but there might also be an adjuster at the connection between the front cable and the rear.
    The important thing to do is avoid over-adjusting the brakes and having them binding. Because they are so small, it is very easy to "over-drive" them without even knowing they are binding.
  5. impulsive
    Brisbane, QLD
    VZ Alloytec
    thanks for your help mate, i gave the brakes a thorough clean with some brake cleaner, checked conidition as far as i know they are ok, maybe i imight just take it to the local mech and get him to do it for me, any idea on how much i would exoect to pay for the procedure?
  6. Calaber
    No, I've always done my own work so I don't have a clue about garage charges. I had the same poor hand brake performance until a couple of weeks ago, but the simple cable adjustment I outlined fixed it, though I had already de-dusted and checked the rear linings.
  7. impulsive
    Brisbane, QLD
    VZ Alloytec
    so u think the old dust-a-roonie will fix it? I might re-do it later on tomorrow...
  8. Calaber
    Because the parking brake is a very small drum brake assembly, it tends to retain any dust from the linings. This dust covers everything inside the drum and if it isn't completely removed, it can inhibit brake performance. Remember that the hand brake isn't brilliant on these models because it really is just a parking brake, but it should hold you on a hill without needing the foot brake.
    You mentioned that you had used brake-clean, but I believe that the linings should remain dry, so when you remove the disc, use compressed air and/or a small brush to dust out the brakes and the drum. You will find that quite a bit of dust accumulates inside the drum and you might need to sand down the lip that develops inside the outer edge of the drum to facilitate its replacement.
  9. Veriton
    Veriton New Member
    Nthn Beaches, Sydney
    5.7L VZ
    Hey impulsive. First, don't adjust the cable, readjust it back to the point it was at before. Secondly, here's what you need to do:
    1. Remove rear wheels.
    2. You'll now see 2 rubber grommets on the outside of the rotor, remove 1 of these.
    3. Make sure your handbrake is down
    4. Rotate the rotors until the hole without the grommet is at the bottom, now look through this hole with a light and rotate the rotors left or right a bit until you see a cog.
    5. Put a flat blade screw driver in the hole and rotate the cog up or down intil the rotor locks up.
    6. Now rotate the cog the opposite way 2-4 CLICKS, the rotor should move freely again.
    7. Repeat steps 4-6 for the other rotor, moving the cog in the opposite way to the other wheel (ie if on the right wheel you pushed the cog up, then on the left you push it down to tighten the hub).
    Now that you've done this, test the hand brake, does it feel good? If it is, then put the wheels back on, drop the car and test the handbrake out.
  10. impulsive
    Brisbane, QLD
    VZ Alloytec
    i will do this tommorrow.. thanks a lot! i seen this cog and wondered what it was for, makes life a lot easier
  11. famico
    famico New Member
    sydney
    VZ acclaim wagon
    Hey impulsive, I'm new here so be gentle.
    I followed this brake adjustment thread a week ago because my handbrake on my VZ (my travelling castle) was getting mushy like a chick flick watchin' woman.
    With previous experience on the VXII executive, It is imperative that the adjustment is made at the wheel end. I say this, as a certain dodgy auto repair centre in Pagewood that rhymes with slay-tart, did an adjustment near the handbrake by fiddling the screw, and I can remember it was sounding like 2 bricks being banged together as the cable suddenly went taut and engaged the rear brake shoes. Very uncool. Not as uncool as going to those hack bastards to get my holden fixed in the first place mind you.
    The process of jacking up car and putting it on stands and removing the rear wheels is a little bit of work, but finding the holes in the hubs is easy, and then lining it up and fiddling with screwdriver on the notched cog. Remembering to go up on one side and down on the other. After dropping the vehicle down, it is satisfying to get proper brake action with 5 clicks like Veriton posted further down this thread, and thanks Veriton for the correct way to fix this problem.
  12. RiCeY
    RiCeY F O R U M W A R R I O R
    Australia
    VZ SV8 6spd 5.7
    Just a note with the VZs if you over adjust the handbrake ie dont back it off enough after it locks the wheel up, you will get a vibration from the rear at around freeway speeds.
    Also, prior to adjusting at the wheels its a good idea to back off the 10mm nut at the handbrake lever, then tighten after adjusting the wheels. 6-8 clicks is normally a good adjustment.
  13. impulsive
    Brisbane, QLD
    VZ Alloytec
    Glad this thread has helped someone else.. as for workshop's, i do most of my own work now.. Atleast i know it is done properly
  14. CAPRILICIOUS WL
    CAPRILICIOUS WL New Member
    WL CAPRICE
    I'll be having a crack at this soon too, all my brake system needs to be readjusted.
    It feels like there is too much contact between my pads and the disks, specially the front wheels.
  15. RiCeY
    Australia
    VZ SV8 6spd 5.7
    How can you have too much contact? What do you mean?
  16. CAPRILICIOUS WL
    WL CAPRICE
    For example if I have the front wheels raised of the floor and spin them by hand there is a slight friction which doesn't make the wheel spin freely.
    When I'm driving at very low speeds rolling with the windows down I can very very lightly hear the contact friction between the pads and the discs.
    Is it supposed to have that minimal friction??
    Other times the brakes again at very lows speed will squeak (non continues squeak Cii...Cii...Cii..) with out me touching the brake pedal at all.
  17. scvs6
    scvs6 BLOWN VS BERLINA
    Tamborine Mountain, QLD
    '10 Holden VE SSV Wagon
    You can't adjust disc brakes, on your car you would only be able to adjust the handbrake shoes which are on the inside the rear brake rotors.
  18. RiCeY
    Australia
    VZ SV8 6spd 5.7
    Pads shouldnt contact discs enough to cause resistance when the brake pedal isnt depressed. Might pay to get the calipers looked at/serviced.
  19. one_and_only2004
    one_and_only2004 Turbo L98 FTW
    Regional NSW Australia
    Z Series Thunder Utility - Turbo
    My rotor has one hole with a grommet, there's a little cog looking thing down the bottom but it won't budge with a screw driver... What gives?
  20. Not_An_Abba_Fan
    Not_An_Abba_Fan Exhaust Guru
    Bunbury, WA
    Prado
    Try harder. If you put the screw driver in too far it won't move. Or it could be wound all the way in, try going the other way, down instead of up, or up instead of down.
