Wow, my 85mm pulley on my htv2300 LS1 is running about 7psi
Cam is 223 228 114
I was under the impression that dropping 5mm on the nose gave about another 2 psi????
My "rough" calcs has the 1.14:1 at about a 25% increase of rotor speed of the 1:1
That gave me a possibility incorrect guestimation of 7 x 1.25 = 8.75psi say 9 psi
My math my well be well flawed as that would have a 80mm pulley with the 1.14:1 rear at about 11psi
My assumptions in relating the ratio to psi increase may be way off, there's no way I'm confident that my stock bottom end would be happy with 13-14 psi, hell, I don't want mine pushing any more than 10 psi
How much power are you making with 13-14 psi?
At 7 psi I'm around 315kwatw/950nm with the 2800rpm converter unlocked and built and 4l60e slush box, so about a guestimated 380kw at the motor, using a guestimated 20% drivetrain loss
I'm thinking I need to ring Harrop as I don't want to over boost or overspeed the thing, they are rated to 18000rpm @7k rpm, I'm currently at 16388, or so says the Harrop PDF
If I add 25% to 16388 x 1.25 = almost 20500 rpm......which won't make the thing happy at 7000rpm, although my highest shift point is at 6300 rpm, LOL, and with more poor rough calcs, has the rotors spinning at around 18500 rpm at 6300rpm, which is on the fast side, but possibly do-able
Arrggg, I hate trying to play math, I may need to ring Harrop tomorrow and see what they say
As long as I'm under 450kw/600hp at the motor I am quietly confident that, with a nice fat tune, the stock bottom end and built transmission will last, well, for a little while at least
And now, my brain hurts
