Makes a lot of sense, I will check door light switch. Just went to shops and it worked, so an intermittent problem.View attachment Audio System.pdf
Here is a wire diagram how it works, its either a bcm or ignition switch issue, I imagine like your lights once the door ls open they turn off, maybe its the door switch if that's how its set up, next time it stays on keep pressing the door switch in rapidly to see if it switchers off, its only a theory good luck.
Hi Trevor. I remover door switch and it was corroded. Put in vinegar for a few hours and replaced. It is working fine now.View attachment Audio System.pdf
Good to here, thanks for letting us all know.Hi Trevor. I remover door switch and it was corroded. Put in vinegar for a few hours and replaced. It is working fine now.
Thankyou for your help.
