Help. Cabling????
acarmody
Donati..Whoa Green
VX Berlina
Wow that really weird of Pioneer to wire them like that, would be a lot easier to bridge the coils at the sub, but anyway. To OP, to run these subs of the 4-channel, you need to run each sub of a bridged pair of channel at the amp, so channels 1+2 bridged for one sub, and 3+4 bridged to run the second sub. Otherwise your trying to run the amp at 1-ohm per channel, and it won't like that, probably trying to kill itself.
kizza50
VX acclaim S2
Stereo output 4 -16 n bridge output is 2-16, if I was to bridge to channels to each sub, could I then piggy back a speaker off each sub, as I'm running 6 speakers,4 of the deck ATM n the other 2 off the amp
acarmody
Donati..Whoa Green
VX Berlina
Nope because that changes the impedance yet again.
Also the crossovers for the subs is the complete opposite to the required crossovers for speakers.
kizza50
VX acclaim S2
So wat should I do? leave it the way it is lol?
acarmody
Donati..Whoa Green
VX Berlina
Personally I would buy a nice little mono-amp for the sub, and use the 4-channel to power the speakers. You can use a 4-channel to power 6 speakers if your careful, and also depending on the speakers and the amp power figures.
kizza50
VX acclaim S2
Then how do I go about RCA to the mono, will I damage anything if the amp is seeing 1 ohm ? It sounds fine the way it's wired now
vn_v6
Blumpkin
victoria
87 vl limited edition
go mono, no use having a multi on subs....., and monos are alot easeir to setup, and you wont damage anything as long as the mono is capable of handling 1 ohm.............
acarmody
Donati..Whoa Green
VX Berlina
You can just use an RCA splitter.
itchy123
South East Melbourne
Vt Calais
1 ohm ???????? the subs are configured to run 2 ohm when he runs both side terminals in parallel
atm each side is hooked up in 4 ohm config (dual 2 ohm coils hooked up in series)
vn_v6
Blumpkin
victoria
you just fried my tiny arse brain.......
